Fluke 8846A defective due to overvoltage
Discussion in 'Troubleshooting and Repair' started by mechachris, Nov 2, 2020.
  1. mechachris
    mechachris
    7
    Nov 2, 2020
    Hello technician,
    I destroyed a Fluke8846A due to incorrect measurements.
    I swapped the primary and secondary side of a 24V transformer and created an overvoltage.
    I had about 900 to 1200 volts at the measuring tips
    I can no longer recognize the SMD imprint on component Q41 in the SOT23 housing.
    Can someone tell me what is written on component Q41?
    I was able to reconstruct everything else.
    Greeting,
    mechachris
  2. bertus
    bertus Moderator
    1,480
    585
    Nov 8, 2019
  3. mechachris
    mechachris
    7
    Nov 2, 2020
    Thanks Bertus for the quick answer.
    But unfortunately I can't see the imprint of C41 on the pictures.
  4. mechachris
    mechachris
    7
    Nov 2, 2020
    don't know the capacitor C146 either, but there's no print on it either.
    I have to estimate the value
  5. bertus
    bertus Moderator
    1,480
    585
    Nov 8, 2019
  6. mechachris
    mechachris
    7
    Nov 2, 2020
    Hello Bertus,
    unfortunately there is no usable picture available.
    I attached a picture for the component search
  7. bertus
    bertus Moderator
    1,480
    585
    Nov 8, 2019
    Hello,
    Unfortunately, the parts are not carrying any numbers on the picture of the given site:
    bertus
  8. mechachris
    mechachris
    7
    Nov 2, 2020
    Yes exactly!
    On the component Q39 is written PD that means BSS84LT1G = Mosfet transistor P channel.
    There are also 2 letters printed on component Q41. But the photo reflected it.
    You have to moisten the component and illuminate it with a lamp, then you can see the imprint.
  9. 73's de Edd
    73's de Edd
    3,044
    1,286
    Aug 21, 2015
    If that was being the case then, and you WERE able to make them out, why didn't you give those two alfa /numeric symbols to us ?
    Looking at the foil paths, associated with that transistor pair, they seem to be interconnected, akin to Darlington or Sziklai pairing combinations of bipolar circuitry.
    Also, can you determine what Mx pin is involved in receiving that sole related trace from them, that is routed down and over to the right, and then going under the Maxxim 329 octal analog multiplexer 16 pinIC . . . . . . What pin number is it being?
    Thereby confirming if they are being related to an inputting from or an outputting from that MUX chip . . .with my leaning towards their receiving an MUX output.
  10. mechachris
    mechachris
    7
    Nov 2, 2020
    the Q41 burned down on my mainboard.
    There is no print. That's why I don't know which component to use.
    I only know that it is a SOT23 housing.
    I take a photo of my circuit board and draw the connection.
    LG
    mechachris
  11. mechachris
    mechachris
    7
    Nov 2, 2020
    I drew the connections.
    Q39 = BSS84L I got that from a picture from the Net
