Fluke 8375A is not too stable
Discussion in 'General Electronics Discussion' started by (*steve*), May 23, 2014.
  1. (*steve*)
    25,497
    2,839
    My old Fluke 8375A is misbehaving. This might turn into a repair thread :)
    I think it has been getting worse, but yesterday the problem was so bad the meter wasn't much better than a 3 1/2 digit meter :-(
    The main problem was that with a reasonably high value resistance (10k to 100k) the readings would occasionally be right, but were drifting in the last 2 (and sometimes last 3) digits.
    It seemed to get a little better as the unit was left on for a while, but it was not really useable.
    Oddly enough, occasionally (more often that you could attribute to chance given the +/- 300 or so in the last 3 digits) the reading was spot on.
    My suspicion at the moment lies with the power supply. I'm going to have to take it apart to see if any of these 40 year old capacitors are not as good as new.
    Looking a the documentation for this unit last night, I noted that it has a large number of germanium transistors. *wow*! I sure hope I don't have to replace any of those.
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Wow, that's an old meter!
    How many digits?
    Please keep us informed Steve.
  3. davenn
    davenn Moderator
    13,866
    1,958
    I suspect its almost as old as Steve ;) haha
    electro swap time, Steve :)
    Arouse1973 likes this.
  4. (*steve*)
    25,497
    2,839
    No, It's significantly younger than me. And it's 5 1/2 digits.
  5. (*steve*)
    25,497
    2,839
    After opening it up and finding mid 1973 dates stamped on the inside cover...
    1) It's still not as old as me
    2) the power supply capacitors still measure OK for capacitance and ESR
    3) Connecting the guard terminal to the "low" input helps a lot
    4) Pressing the "filtered" button on the front panel makes it even more stable
    Chalk this one up to operator error.
    Oh and it has a resolution of 1uV on the 0.1V scale.
    The zero adjust needs a little tweaking but that's a front panel (via a screwdriver) adjustment
