Fluctuating ADC Reading for 4-20mA Pressure transducer input
Discussion in 'Microcontrollers, Programming and IoT' started by BHARGAV SHANKHALPARA, Aug 2, 2018.
  1. BHARGAV SHANKHALPARA
    35
    Nov 6, 2013
    Hello...
    I am working on one project of water pressure measurement, in which i used pressure transducer which gives me output between 4-20mA Current form.
    I am using one 250 ohm resistance to convert current into voltage, and than i give this voltage to ADC of arduino UNO channel 0 (A0).
    ADC reading is continuously fluctuating up to 10 decimal numbers.
    I have also check by connecting multi-meter and measure sensor current reading, for particular pressure. but current reading is stable (even not fluctuate 1 or 2 points.)
    also i have checked voltage value after 250 Ohms +Ve and ground. converted voltage is also showing very stable.
    but why ADC reading is fluctuating..?
    i am using arduino uno, i doesn't have any changes in AREF, AVCC etc...
    please suggest effective solution,
    Thank in advance.
    My code is as follow
    const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
    int sensorValue = 0; // value read from the pot
    void setup()
    // initialize serial communications at 9600 bps:
    Serial.begin(9600);
    void loop()
    // read the analog in value:
    sensorValue = analogRead(analogInPin);
    // print the results to the Serial Monitor:
    Serial.print("Reading: ");
    Serial.println(sensorValue);
    delay(1000);
  2. (*steve*)
    25,384
    2,771
    Your measurements with a multimeter may not show rapid changes. Have you tried looking at the voltage using an oscilloscope or even your multimeter on an AC range?
    What effect sites placing a capacitor (say 1uF) across the resistor have?
    If you connect the ADC input to a voltage divider across the power supply, do you get a more constant reading?
