Okay Larry, let me tell you my story.
Here in Demark we pay so many taxes, that we have to do
everything ourselves
For 5 years ago i bought a old military coast control boat.
30 feet, 5 tons, two Mercedes 180 installed.
I was happy, my own boat, yappiiii.
But then the engines began to fail, they were old, very
old. I took out one, and send it for a complete overhaul.
That costs me in the area of 2000 Dollars. NO MORE i said.
So when the second began to fail, and was due to a
overhaul, i simply took out the old engines, and then
started to remove all the old wood that was rotten. One
thing lead to another, ans soon i was standig there with a
30 foot open rowboat. Everything was rotten. I had to
reinforce the bow with 10 layers og glasfiber, because
there was absolutely no wood underneath.
At the same time i removed about 15 pipes through the hull,
they were of no use, and i don't know what they ever where
there for. So i started looking around for some suitable
engines (cheap), and found two Golf Diesel 1.6 liters on
the Internet, they costs me about 80 $. It took me (and a
friend) about 2 months making my gears fit on the new
engines, but finally we succeded. Then i started rebuilding
the entire boat, completely new interior, and new top.
It has taken me almost 3 years, and i am still not done
yet. The gears were of the type with a loooong gearchange
handle, so usual morse cable would not hold for long ( i
had already broken 3). So i thought that maybe air pressure
and one air piston on each gear maybe could do the trick.
And despite what everybody told me, i made it work. I also
had to make a new fuel tank. There were two in the old
days, but they flowed from one tank to the other, in a 1/4
inch hose, that took about 1 hour before they leveled out.
The fuel outlet was in the bottom of the tank, so my
filters keept getting real dirty. Almost everything was
made by peoble that had absolutely no idear about what they
were doing. So redoing the boat was a good idear, it has
become much stronger and reliable, and now i know exactly
how everything is put together.
So now i can enjoy sailing again, but there still needs a
lot of finishing touch to the boat.
Tell me, just to make me real shitty overhere, what is the
comon price on two used disel engines, around 70-100 HP,
with gear and everything?
If you like i can send you a link to some pictures that
illustrates me rebuilding the boat.
Wkr
Franz
