Floppy Drive not working
E
Efandin
I just manage to get my new system I put up booting and having WinXP
Pro installed. However, on the first screen it gave me a message that
"Floppy disk(s) fail (40)". However, when I check property or trouble
shoot the floppy drive, it says "the device is working properly".
But when I insert a diskett, it cannot be read. The floppy drive was
from my old P2 system. What wrong? Thanks.
B
Bee and Baloo
PS2? Floppy drive is an IBM special? May not be a standard PC drive - I
would try another. If I recall correctly PS2 drives were 720 K also will
not read a HD disk. Is it set to 720 K in the bios?
HTH
Warren
Jerry Greenberg
Change the drive to one that is more modern, and conforms for the BIOS
in your mother board. It should work, if there is nothing defective.
Jerry Greenberg
http://www.zoom-one.com
Q
Quack
there can be 3 reasons for this;
- your floppy drive is misconfigured in the BIOS.
This is easy to fix, follow the on-screen menus and instructions.
(read the motherboard book if necesary).
- your floppy drive cable is plugged in the wrong way around.
I find that when upgrading old systems, some older floppy drives had
an reversed connector - although in modern machines it is standard to
face the RED side of the ribbon cable to the power side of the drive -
some of these 'standards' were not so standard a few years back.
When your system boots, or windows trys to access the drive, does the
floppy led light up ? If not this is most likely the problem.
0R is it always lit ? In this case, this is also most likely the
problem.
Try reversing the cable and see what happens.
- your floppy drive is old, incompatible or faulty.
get a new one :)
windows will always say that if the bios says you have one.
Again, when you 'insert' a disk, what happens on the floppy drive LED
(see above)
Alex.
BTW - everyone said "ps2" in response to the old system - but i would
have taken "P2 system" to mean his old "pentium 2" machine.
