M
Mark
I'm designing a circuit to read the output from several pressure
transducers, buffer the signal and then digitize it.
The pressure transducer provides a 0-10V signal and the output is stated
as isolated. Contacting the Manufacturer (Taber) they state that they
use a small DC-DC converter within the unit to convert 28V to a lower
voltage to power the electronics inside the unit. Thus, the output is
floating and the low side of the output is not connected to the 28V RTN.
I want to read the signal differentially so I'm using an instrumentation
amplifier. Since the sensor is "floating" I placed a resistor from each
input (+ & -) on the amplifier to the local circuit ground to account
for the input bias currents. The resistors to ground in front of the
in-amp will set the common-mode of the sensor when the mux switch is
closed. So this should work OK for the selected channel through the mux.
But then I realized the other channels feeding the mux, that are not
selected, are still floating and do not have any reference to the mux's
ground.
Is this design acceptable, or should I reference the sensors output to
my local circuit ground on the input side of the mux also?
Mark
ground.
Mark
