Adam,
The RC circuit is somewhat taking the load from the circuit without, I'm thinking, burning energy (I have not tested for current, but the circuits themselves are at ambient temperature--and, in fact, the RC circuits are replacing a 4w lamp I started out with).
KrisBlue,
The dimmer in the circuit is represented by the on/off switches. There is no issue in the dimming feature, just on and off.
I figured the .47uf would be sufficient--which it is, or at least, seems to be for the random flashing issue when the dimmers are turned off--but, perhaps, I need to look at other capacitance values to see if a different one might work, As far as where the idea came from, it was from my own thought processes.
The brand of dimmers is X10, models, W467 and W477 (I think).
I mentioned in an earlier post that the bulbs were all the same: Wrong. They're both Utilitech brand lamps, the six are reflector style LBR30HO, 20W, 1150 lumens, model not apparent; the two are A15 style LA100/830, 12W, 1100 lumens, Model UL#E330072 (I could find no spec sheets or links to same).
One other note, when I pulled out one of each light to get the answers to KrisBlue's questions, the on state of both lamp circuits, five and one, instead of the blinking you see on the video, the blinking on the single bulb became rather rapid, as if it were taking up all the trace voltage in the circuit. And that the six lamps do not blink at all, not even when matched in number with the other circuit, perhaps trying a different bulb would give a different result--maybe even correct the issue.
