Flickering light (LED) circuit
Discussion in 'LEDs and Optoelectronics' started by Tipiford, Feb 9, 2015.
  1. Tipiford
    Tipiford
    17
    Feb 9, 2015
    I have introduced RC circuits to two LED lamp circuits on the same electrical leg (the RC circuits prohibit the LEDs from blinking when turned off on a dimmable switch). When either lamp circuit is turned on, it behaves normally, but when both are turned on, the one circuit with two LEDs simultaneously flicker; the other circuit with 6 LEDs remains solid. Any ideas here? TaskLiteCircuit.jpg
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    C2 is shorted and does nothing.
    Circuit2 is shorted, so how does it work at all?
    I suspect that interference on the power line is upsetting the timer in circuit2. You may have to investigate and fit some suppression components.
  3. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Oops, Please forgive, I had redrawn my initial schematic and took out the leg on Circuit #1, but overlooked Circuit #2. I edited the OP and inserted an updated graphic.
    If line interference is causing the flicker, shouldn't it do so on both circuits, or even circuit #2 when energized alone?
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    What colour are your LEDs? Try switching both on and covering up the 6 LEDs with your hand, does this help?
    Adam
  5. Tipiford
    Tipiford
    17
    Feb 9, 2015
    The LEDs are all 2,700K, dimmable, the 6-lamp circuit is spaced some 8x6' on the ceiling (track lights) and the other two are hanging lamps over a kitchen bar (they're all the same, BR30 bulbs).
  6. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    It must be a loading issue then. If the voltage is dropping by a small amount this may not be noticed so much by the 6 LEDs as compared to the 2 LEDs. Can you disconnect some of the 6 LEDs and see if that helps?
    Adam
  7. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Thanx, Adam, but I still get a flicker with two and two.
  8. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    That's very odd. Not sure then. Their not on a dimmer by any chance?
    Adam
  9. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Here's a video of what's happening, I had to make it pretty small to conform to the forum's file size limit.
  10. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Looks like both are flickering?
    Adam
  11. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Yes both light circuits are on dimmer switches. I added the RC circuit to control some pretty erratic behavior, such as when the circuits are de-energized, all of the bulbs would blink in random order. I'm hoping to find a solution to this so as not to have to replace the dimming switches.
  12. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Ah you can't dim all LEDs, they need to be dimmable types. Are they?
    Adam
  13. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Those two flickering are on the one circuit, the 6-bulb circuit remains steady (if you can see it--it's a pretty small video--there's one can on the track light on the ceiling that's steady).
  14. Tipiford
    Tipiford
    17
    Feb 9, 2015
    Yes, all are dimmable, that's why I'm trying to keep the switches. I could put in regular singles and 3-ways to correct this; but hoping not to.
  15. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Some of the issues that may occur when a dimmer is incompatible with an LED lamp are:
    • Flickering - Lamps will flicker (can also occur if a non-dimmable lamp is used)
    • Drop-out - No light output at the end of the scale
    • Dead travel - When the dimmer is adjusted there is no matching change in light output (light may not dim to acceptable level)
    • Not smooth - Light output may not go from dim to bright linearly
    • Multiple lamps - issues may become apparent when multiple lamps are added
    • Damage or failure - LED driver, circuit or LED is damaged or fails.
    • Load below minimum - The power load of the LED lamp is below the minimum required by the dimmer
    • Mixed models- Different models of LED will likely have different drivers - since drivers behave differently this could result in dimming issues.
    Adam
  16. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    But the dimmer switch needs to be the right one also
    Adam
  17. Tipiford
    Tipiford
    17
    Feb 9, 2015
    According to some, what I am looking for is a network that will correct this without spending $100 on two switches.
  18. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    How many dimmer switches do you have?
    Adam
  19. Tipiford
    Tipiford
    17
    Feb 9, 2015
    There's a single pole on the 2-lamp circuit and a 3-way on the 6.
  20. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    So it's only two light banks then? have you looked into the prices of the dimmers are they that exspensive?
    Adam
