K
[email protected]
I am in the process of designing a Blackfin DSP board and a
PAL/NTSC decoder board. I want to connect these two over a 20pin
connector. I've two? options.
1) To mount the decoder directly on the DSP board
2) To use a Flat Ribbon Connector(~15cm length) between them.
The decoder runs at 27MHz with current ratings of 2mA for I/O and 4mA
for clocks
The DSP board controls the decoder with I2C(current rating ~10uA?).
Maximum Load: 200pF
My question is that If I resort to a Flat Cable then will the DSP be
able to drive I2C and also what about other effects like Cross-talk,
distortion etc and do I need to use Termination Resitors for I/O's
also. Thank You.
for clocks
Maximum Load: 200pF
also. Thank You.
