flashing light circuit
Discussion in 'LEDs and Optoelectronics' started by paul60, Apr 16, 2015.
  1. paul60
    paul60
    22
    Dec 11, 2010
    i am looking for a circuit that will flash a led strobe light about every 2 seconds
    a light like the ones used on bikes but not a continuous light like the ones on bikes
    what led types would i need for this, as i need a very bright light.
    this will be used daytimes only.
    i have a couple 555 ic
    thanks this is the type of thing i am thinking about
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    So, you're wanting to have a single flash every 2 seconds. Are you fine with drift? Perhaps it flashes once every 2.2 to 1.8 seconds.
    Please be aware that flashing light for automotive purposes are illegal in many states and provinces, especially if they are using a reserved color for law enforcement.
    What do you plan to power it with?
    As far as 'which' leds to use. Go do a quick search for 3 Watt LED's you will find many come mounted to a small star like metallic plate. They can be quite bright.
  3. paul60
    paul60
    22
    Dec 11, 2010
    yes drift is ok this is to be used a a pest deterrent i have a problem with monkeys in my garden and i think a bright light that comes on every 2.3 seconds might solve the problem this will be powered by a 12 volt supply
    this supply was used to power a tape deck.
    so you think a 3 watt led is my best bet?
    if i can pick something up instead of building thats another way i can go
  4. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    If you are fine with drift, a 555 timer will work just fine.
    As far as the LED is concerned, I was mentioning a 3W LED based on the supplied video. You can get LED in anything from little 25mW to 100W.
    I suggest you hop online and look for two things:
    High power LED modules.
    12V LED power supply matching the LED module.
    I bought some 10Watt LEDs and little drivers from DX a couple months back. They are brighter than the 60Watt frosted incandescent lamp I had in the ceiling.
    If you'd like, I can take one outside and snap a picture for you in daylight to see if it's bright enough for you.
  5. paul60
    paul60
    22
    Dec 11, 2010
    thanks Gryd3 a photo would be a great help thanks
    will go online and see what i can find thanks allot
  6. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Of course.
    Now... I have a bad memory :p so If I don't post a pic by tonight, send me a message as a reminder!
  7. paul60
    paul60
    22
    Dec 11, 2010
    Hi Gryd3 can you send me the link to the leds and power supply you purchase from DX?
    thanks
  8. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
  9. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    I have 'some' pictures already... none outside which I think would be a better comparison.
    The blue LED is a 1Watt LED
    The white is a 10Watt LED as linked in my previous post.
    One image is of one of each LED side by side, the other I have covered the 10W LED with a translucent plastic cup.
    The last, is a picture of all 3 10W LEDs lit up. I have 3 60Watt frosted incandescent bulbs in the ceiling fan turned up to full brightness, and a 40Watt clear incandescent in the lamp in the section to the left. The light in the doorway is from 2 T5 20Watt fluorescent tubes. The LED's cause the camera to adjust and make the room look dimmer.
    *These were taken when I first got them in December.
  10. paul60
    paul60
    22
    Dec 11, 2010
    thanks i will order a couple of the 10 watt ones i will need a timer for the 2-3 seconds . i am thinking a longer delay might work better up to 10 seconds
    is there a power supply on Dx i can get to do this?
    thanks
  11. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    In the pictures I used an old desktop power supply.
    Anything that gives you ~12V will work fine.
    The drivers that come with the LEDs have an unused 'inhibit' pin. You can attach a little wire to the inhibit pin to turn the LED on and off. A 555 timer can easily control this without requiring transistors to switch the 12V line on and off. In this case, the 12V supply would always be left on.
    Alternatively, you can use a transistor to cut power to the drivers instead. Again this can be controlled by a 555.
    How long do you want the light to stay 'on' ?
  12. paul60
    paul60
    22
    Dec 11, 2010
    i think 5-6 seconds will work
  13. paul60
    paul60
    22
    Dec 11, 2010
    the power supply i have is 115v 4amps output 12volts dc
  14. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    It's a long delay, but a 555 can certainly do it.
    Alternatively, if this is an animal deterrent, they may learn pretty quickly that a light that turns on every few seconds is not threat... Heck, the animals in my yard ignore the motion light. You may want to make it activate irregularly.
    (Many ... feline challenged people are using motion activated sprinklers.)
  15. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    A Single 10W Led will draw almost an amp.
    So, is the 4 Amps the 'output' of the power supply you have? It will work nicely for 3, and 'maybe' 4, but that would be pushing it.
  16. paul60
    paul60
    22
    Dec 11, 2010
    yes the output is 4amps and i only need 2 10watt leds
    i willgo ahead and order them but i know they will take a month to get to me
    i live in Barbados
