Flashing LED PIC
Discussion in 'Microcontrollers, Programming and IoT' started by Lebo, Oct 27, 2009.
  1. Lebo
    Lebo
    Oct 27, 2009
    Hi
    I need help with this code in designing a a pic circuit that will use two led's to show an output.
    led one should flash using a delay of 100ms
    led two should use a switch meaning the switch is closed the led will be on when the switch is openled is off. consisting of a logic diagram and flowchart
