Flashing 5watt led?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
The reason I decided on 1/2W resistors is that metal film 1/2W resistors are the same size that carbon film 1/4W resistors used to be. 1/4W resistors may actually be harder to get hold of.
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
Well I ran in to a problem, Got my stuff in the mail today and the heat sink they said would work for it is about size of my fist and about inch thick. Talking to them trying find one smaller but if there isn't one do you guys think It would be possible cut the sides of the heat sink off and just keep the middle of the heat sink that about inch thick? The threshold temperature for the LED is 150ºC and I got a Thermal imaging camera I could use to see how hot its getting.
Photo below is the Heat Sink they sent me
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
The data sheet certainly does show the dimensions. I looked at it and the OD is 2.75 inches. Since my circuit pulses the LED's with a very short duty cycle they will be running much cooler than with constant current. I know that there's a simple formula to calculate what your average power will be but my head is too clogged up with a head cold to figure it out.
Chris
7,682
7,682
I have an RGB 3-Watt LED on a star that has up to 2 colors at full brightness continuously on, (i.e. 2 Watts) and it gets hot to touch but not enough to burn you, with no heat sink. I am pretty certain you can get by with no heat sink at a duty cycle of even 50% and it will only be warm.
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
Bob, thanks for your input. I wasn't certain if he'd need a heat sink.
Chris
(*steve*)
25,510
25,510
Attach the LEDs to the heatsink while you're testing stuff. If it accidentally gets stuck ON at full power, this will make the difference between the LED getting far too hot (and possibly being damaged) and running at a normal temperature.
Once everything is operating normally, you can remove the heatsink and verify that the star itself is sufficient (you should be able to touch it, leave your finger on it indefinitely, and have it not feel hot -- warm is OK).
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
Got the heat sink down now. But need know if I have the following thing correct for the Q1/mosfet Drain goes to the negative of the leds Gate has the resistor going to it from pin 3 of the 555 timer, and Source goes to a ground/wire
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
Yes, all correct.
Chris
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
About time I got something right :) Im narrowing down to the finish and I need know If i got the following thing correct as well. I Know I got the Negative to Q1 mosfet/Drain and Positive wire from led to the 2w resistor then wire to 8 of 555 timer. But I need know if the wires hooked to the LEDs are right. Take look at the photo below
(*steve*)
25,510
25,510
No, they're in parallel. Connect your +ve wire to the + lead of one of them. Then connect the -ve terminal of that one to the + terminal of the second. Connect the - terminal of the second to the drain of the mosfet.
It's kinda like batteries.
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
No, the series circuit part is right but your polarities are wrong.
Chris
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
So capacitor (c1) is right? but not the led hook up still. Other than me asking 50 times could you please show me what I have to do with the image I added?
(*steve*)
25,510
25,510
You want this:
attachment.php
A picture is worth 1000 words. This is what I was trying to describe. My apologies if I was unclear.
On each star, the two connections labelled + are connected together, and are the two labelled -. Your wiring above would have resulted in an (accidental) short circuit.
Yes that capacitor sounds right. Make sure you know which lead is positive because tantalum capacitors don't like being connected the wrong way around.
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
Thanks I got that down now and i've got every thing together but need be sure where im putting my power wires to? Pin 8 and 1?
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
Pin 8: Positive (+)
Pin 1: Negative (-)
Chris
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
ah dam think I short my circuit. I used a test LED with about same amount of volts/other stuff as the LEDs im using for this thing, to if it would flash be4 I put the real ones on it. The light wasn't flashing it was just on. Took it off when I seen that and when I did it again it wouldn't come on. Think I put c1 capacitor on wrong pin by mistake got take 2ed look at it. But It could been the other capacitor that goes beside it. It didn't have a Positive/Negative it looked like this http://www.westfloridacomponents.com/mm5/graphics/00000001/.0022uf-3000v.jpg
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
If you want to test the circuit with standard LEDs you'll have to replace R3 with a higher resistance. Anything from 100 Ohms to 1KOhms will suffice for testing. The disk cap in your link would be the same type as used on pin 5, which is 0.01uF. This is not a critical value though. Anything up to 0.2uF will be practical.
Chris
EDIT: C2 is not a polarized cap. It can be connected in either direction. C1, which is the timing capacitor, must be connected with the positive (+) lead connected to pin 6.
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
Sorry haven't said anything think I've got the flu but almost over it now
samsm255
Dec 29, 2012
115
Dec 29, 2012
115
Just going tell you what I’ve done because I believe the problem is with the D1 Diode
Diode/D1
1:I have the anode side of the diode going to pin 7
2:The cathode of the diode to R5 the 10k resistor
3:R5 resistor goes to pin 6 with c1 positive
4:I have R2 1m resistor between R5 resistor and the anode of the diode
5:R1 1k resistor to anode of the diode to wire going pin 8
Ground for capacitor
6:I have a wire from pin 1 the (ground) going to the pin 5 area (not hooked to it)
7:I have C1 and C2 going to that ground wire
Q1 Mosfet
8: D going to negative of the LED’S
9:G with R4 10ohm resistor
10:I have another wire from pin 1 ground and it goes to the S The wire going to the grounds for the caps are only hooked together at the pin 1 ground but I don’t have the S and caps on same wires
Power
11:Wire from pin 8 going to R3 (5r/2w) resistor then to positive of the LEDs
12:The negative power for the LED Is the S of the Q1/Mosfet
Side thing:I forgot the switch in Pin 4 be4 I turned this thing so could that have been the whole problem of why the light wasn't flashing then not working at all?
Going fix that soon as I find a switch
