Flashing 5watt led?
Discussion in 'LEDs and Optoelectronics' started by samsm255, Jan 8, 2013.
  1. samsm255
    samsm255
    115
    Dec 29, 2012
    Can someone help me make a 5watt LED flash? Maybe a diagram or a video on how make a flashing circuit for a 5watt LED. Need a good place buy the led and names of the parts I'll need for this projects.
  2. CDRIVE
    4,960
    652
    May 8, 2012
    In order to supply you with detailed information we need detailed information from you.
    What color LED will you use? What power supply will you use? What will the flash frequency and duty cycle be? Will this be portable?
    Chris
  3. samsm255
    samsm255
    115
    Dec 29, 2012
    Like make it red or white. Like have it ran off a battery depending on how many volts it will need. So it will be portable. And the other things you said bit hard for me tell because Im new at this stuff.
  4. CDRIVE
    4,960
    652
    May 8, 2012
    Keep in mind that white LEDs can require an operating voltage more than twice that of a red LED. With this in mind a direct battery source to power either will necessarily waste battery power when used with red LEDs. If you pick one or the other we can design the battery voltage for minimum power loss, thus max efficiency. Of course you could use a small boost converter but they have loss too.
    Chris
  5. samsm255
    samsm255
    115
    Dec 29, 2012
    Do you have any places you may recommend buy led's from on the web?
  6. CDRIVE
    4,960
    652
    May 8, 2012
  7. samsm255
    samsm255
    115
    Dec 29, 2012
  8. (*steve*)
    25,501
    2,841
  9. samsm255
    samsm255
    115
    Dec 29, 2012
    I wouldn't have worry about any over heating would I? Its going be flashing not a constant light. Worried about that because ebay screwed me over with a 1,000lumen flash light be4 that didn't have over overheating protection
  10. (*steve*)
    25,501
    2,841
    It depends totally on the average current. (well not totally -- the flash rate and the peak current have an effect. If the on time is well under a second then average should work out nicely).
    If the average current is 20mA, then no, you won't require a heatsink. If it is 200mA you will.
  11. samsm255
    samsm255
    115
    Dec 29, 2012
    What do you mean by their pretty small? and what does surface mount mean?
  12. CDRIVE
    4,960
    652
    May 8, 2012
    Surface mount components typically don't employ wire leads that feed through PCB holes to be soldered on the bottom side of the board, They require superior soldering skills, as the typical soldering iron tip can be larger than the entire component. They're soldered to the component side of the board.
    Chris
  13. samsm255
    samsm255
    115
    Dec 29, 2012
  14. samsm255
    samsm255
    115
    Dec 29, 2012
  15. CDRIVE
    4,960
    652
    May 8, 2012
  16. samsm255
    samsm255
    115
    Dec 29, 2012
    What about the 555 timer/with a led Would that be the same ideal of this project with a 100+ lumen light
  17. CDRIVE
    4,960
    652
    May 8, 2012
    I'm not sure what you're asking but there are varied versions of the 555. An LM555 by National Semiconductor specs source and sink output @ 200mA Max. If you need more drive current you can have the 555 drive the base of a BJT or the gate of a MOSFET.
    Chris
  18. samsm255
    samsm255
    115
    Dec 29, 2012
  19. CDRIVE
    4,960
    652
    May 8, 2012
    As I stated in my last post: If your LED is going to operate at over 200mA you'll need a driver. What current level will this LED operate at? What will your power source be and what operating voltage? If I find time I'll draw it for you. In the interim try Googling "High Power 555 LED Driver".
    Chris
  20. samsm255
    samsm255
    115
    Dec 29, 2012
    Ok understand that now. Also think I found the light I want. Here link to it http://www.digikey.com/product-detail/en/LR W5AM-HZJZ-1-Z/475-2821-6-ND/2176391
    But I need be sure that's 118 lumens and I also need find a lens for the light but don't know what size I need. Came across these and looked like type of lenses I would like try and use. Here is the links to the 3 types of lenses I came across
    http://www.digikey.com/product-detail/en/10415/1066-1045-ND/2641661
    http://www.digikey.com/product-detail/en/FA10327_OSS-SS/711-1001-ND/1628589
    http://www.digikey.com/product-detail/en/OP-015/350-2014-ND/1240396
    Cant say thanks enough for helping me out with this stuff :)
