G
Guest
Dear All,
I am using MXIC MX29LV160BT/BB FLASH rom, sometimes the flash
rom write data will fail. I system blocks as below:
Memory Card => Card Reader => I/O detect interrupt => Read data to memory =>
Write data until finish.
I found our firmware will check the data after we write, and I check the
MIXC MX29LV160BT/BB SPEC, it will go with follow steps:
1. Write Data AAH
2. Write Data 55H
3. Write Data A0H
4. Write Program Data/Address
5. Data Poll from system
6. Verify Data Ok? if not then loop.
Can we guarantee the write data procedure is correct after step.6 ( Pass
Verify Data ) ?
If there is a hardware error( some bit(s) be enforced to high or low, etc ),
does it possible pass the step.6 ? What I want to say is, we already check
the target data is the same as source, so I think the hardware part is
correct, am I right?
Questionable:
1. Does the data from memory card correct?
2. Does memory allocation possible to be mixed?
These are only two reasons I can imagine...
Does any other possible thing?
Thank you so much for your help.
Best regards,
Boki.
1. Write Data AAH
2. Write Data 55H
3. Write Data A0H
Verify Data ) ?
Questionable:
Best regards,
Boki.
