D
DaveC
A nice designer desk lamp uses those l.v. (12v) 2-pin halogen lamps. Each pin
contact in the socket consists of 2 C-shaped halves that are spring-loaded to
hold the pin.
Over time, these socket halves have pitted due to the extreme heat.
Connection is now intermittent. If I hold the bulb at an angle (usually twist
it in the socket a bit), the bulb goes full brightness. But left on its own,
it flickers and buzzes.
I removed the bulb and using a very small rat tail file, cleaned up the
contacts, but this was only a temporary fix.
This is a nice (and expensive) lamp that I'd like to keep. What are my
choices? I guess I could solder the lamp to the socket components now and
whenever the bulb gives out.
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
[email protected]
This is an invalid return address
Please reply in the news group
hold the pin.
DaveC
[email protected]
