Fitting an fm antenna to my stereo radio
Discussion in 'Audio' started by geordief, Nov 24, 2021 at 5:08 PM.
  1. geordief
    geordief
    3
    Wednesday
    • I got a Akai aa-m8l stereo radio receiver second hand and it has come without an fm antenna although there is a point on it at the back for a 75 ohm antenna.
      It looked like a terrestrial tv antenna would go into it (I have a few) but it was little too large.
      Can I order this part online (or from shop) and work away as if it was a normal tv antenna?(attach a coaxial
      cable and solder a couple of extensions)
      Or is it just as easy (and cheap) to buy a 75 ohm fm radio antenna)?
      [mod edit: removed social media links]
    Leave a Comment
  2. bertus
    bertus Moderator
    2,136
    806
    Nov 8, 2019
  3. dave9
    dave9
    1,145
    311
    Mar 5, 2017
    Just get a whole antenna, F type male, wire or mast already attached. Examples:
    https://www.amazon.com/75-ohm-fm-antenna/s?k=75+ohm+fm+antenna
    If you have bad reception and need a roof mount antenna or extended outside, yes you could run coax to an antenna element but if a long run, will need an amp designed for that frequency band.
    geordief likes this.
  4. geordief
    geordief
    3
    Wednesday
    I just have a house with very thick walls and need a small indoors antenna to "look around the corner" as it were.
    I don't need anything on the roof
    I am getting half decent reception as it is but imagine it will be better if I attach an aerial of some sort to the fm antenna socket.
  5. geordief
    geordief
    3
    Wednesday
    Thanks. That seems to be the job. :)
