Fish finder tranducer compatability
Discussion in 'Boat Electronics' started by David Flew, Oct 28, 2003.
  1. David Flew
    David Flew Guest
    Hi
    I'm in the midst of swapping boats. "New" one is clinker, and has an
    existing through-hull transducer. No visible markings, and no plug on the
    end of the cable.
    I've an existing Lowrance X48 complete with transom mount transducer. I'd
    prefer not to use the transom mount -it means another hole in the boat -
    there are enough of those already. And I'm not going to slip the boat just
    to change the transducer. I know from past experience that the signal
    firing through the planking is virtually useless.
    If I can find another plug for the Lowrance, can I use the existing
    transducer? If it doesn't work, will I damage the Lowrance? Any way to
    test for compatibility? My multimeter can measure capacitance, for what
    that's worth.
    David
