First steps with PIC16F819
Discussion in 'Electronic Design' started by Robbs, Jul 26, 2003.
  1. Robbs
    Robbs Guest
    I've written/plagiarized the following, as my first attempt to do anything
    with a microcontroller:
    ------------------------------------------------------begin code------
    list p=16f819 ; list directive to define processor
    #include <p16F819.inc> ; processor specific variable definitions
    errorlevel -302 ; suppress message 302 from list file
    __CONFIG _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _CCP1_RB2 & _DEBUG_OFF &
    _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_IO
    main
    BANKSEL PORTA ; select bank of PORTA
    CLRF PORTA ; Initialize PORTA by
    ; clearing ouput
    ; data latches
    BANKSEL ADCON1 ; Select Bank of ADCON1
    MOVLW 0x06 ; Configure all pins
    MOVWF ADCON1 ; as digital inputs
    MOVLW 0x00 ; Value used to
    ; inititalize data
    ; direction
    MOVWF TRISA ; Set RA<7:0> as outputs
    MOVLW 0xAA ; Output '10101010b' to
    ; PORTA (I hope)
    ; initialize eeprom locations
    ORG 0x2100
    DE 0x00, 0x01, 0x02, 0x03
    END ; directive 'end of program'
    -----------------------------------------------------------end
    code-------------
    Will this do what I hope it will, simply output 10101010b (0xAA) to PORTA?
    If so, is it safe to check the pins with a voltmeter between the I/O pin and
    Vss? would a series resistor be wise?
    Thank you very much,
    Robbs
  2. Robbs
    Robbs Guest
    Funny how seeing your post in an actual ng can make you see errors. Sorry,
    with corrections:
    main
    ; clearing ouput
    ; data latches
    ; inititalize data
    ; direction
    ; PORTA (in theory)
    ORG 0x2100
  3. Robbs
    Robbs Guest
    Sorry. With corrections:
    main
    ; clearing ouput
    ; data latches
    BANKSEL TRISA ; Select Bank of TRISA
    ; inititalize data
    ; direction
    MOVWF TRISA ; Actually write the
    ; value to the register
    ; PORTA (in theory)
    MOVWF PORTA ; Set RA<7:0> as outputs
    ORG 0x2100
    ------------------------------------------end code-----------
    Is the last bit of code necessary, under 'initialize eeprom locations'? it
    was part of the example code supplied with MPLABS, and I'm not sure exactly
    what it does.
    I realize that one pin on PORTA (pin 5, i think) is an input only.
    Robbs
  4. Ishaan Dalal
    Ishaan Dalal Guest
    CLRF TRISA will do just as well.
    Code looks OK, comments are skewed -- MOVLW 0xAA moves the literal to the W
    reg, while MOVWF PORTA actually outputs 0xAA to PORTA.
    Yes; no series resistor needed; but 8 LEDs with series resistors might be
    easier to decode.
    Not for whatever your main code does.
    Then that pin is permanently tri-stated -- you will see nothing on that pin,
    unless you force it by using a pull-up or pull-down resistor.
  5. Leon Heller
    Leon Heller Guest
    It would be a good idea to end main with something like
    stop:
    goto stop
    checking with a meter is OK, you don't need a resistor.
    Leon
  6. Your program will do unexpected things after it crashes at the end of your code.
    This is not a PC, you must provide some code to either rerun some of the same
    code, some other code or do nothing. The way you wrote it, it will run whatever
    garbage follows your code.
