H
H. Dixon
I'm using Slone's Tab book to learn the basics. It's pretty good so
far although once in a while the book takes bigger leaps so I stumble
a bit.
What I've got so far is the the two 24V transformers with the
primaries in parallel, the secondaries in series. I've tested the
outputs from each secondary (about 28V each) and the secondary circuit
common reads 50V. I've added a 250V 6A bridge rectifier and attached
the free secondary leads from each transformer to the AC inputs on the
bridge. The bridge shows 50V DC out.
The book has me (temporarily) add two 10K resistors - one between the
secondary circuit common and the bridge positive lead, and another
from the secondary circuit common and the bridge negative lead.
Testing DC between secondary circuit common and the + bridge lead
shows +24V.
Testing DC between secondary circuit common and the - bridge lead
shows -24V.
This agrees with the book. His next two tests don't work for me.
Testing" AC" between secondary circuit common and the + bridge lead
shows about 50V.
Testing" AC" between secondary circuit common and the - bridge lead
shows about 0V.
His book indicates I should get about 12V for each. That I don't
understand. Something just
doesnt seem to read right here.
I've rechecked what I've done with the schematic and everything looks
good. All tests have agreed with the book except for these last two.
Any advice much appreciated.
H. Dixon
a bit.
shows +24V.
shows -24V.
shows about 50V.
shows about 0V.
H. Dixon
