D
Dave_s
I need help with the circuit approach to allow me to listen to
every beat of my heart. Do not want to know the pulse rate, only want to
use my pulse to trigger a 555 timer, light an LED and create a
loud beep. Will build the whole thing in a hobby tin to carry on my
belt.
I'd be happy to use an ELECRET MIC element and amplifier and 555 beeper.
Those circuit designs I can create. I'm not sure how to physically place
the ELECRET MIC to allow it to sense my pulse.
I do have a finger cuff from an old exercycle heart rate monitor.
ESD on the exercycle killed the monitor. I think, just guessing, that
the finger cuff has both an IR LED source and a IR detector [PIN
diode?].
I'd be just as happy to use the finger cuff but I need some help with
the circuit to drive the IR LED source and sense the IR or PIN
detector. The finger cuff terminates into a tiny stereo ring,tip,sleeve
connector.
I've found the IR LED SOURCE but not sure how the IR detector is wire to
the connector.
Is their any other simple approach I can build myself?
I'm avoiding buying any commercial unit. Want to do what I can with
parts on hand and my labor.
Suggestions are very appreciated.
Thank you, Dave_S
belt.
diode?].
connector.
the connector.
Thank you, Dave_S
