Finding phase angle of transfer function for hi and lo pass filters
Discussion in 'Electronics Homework Help' started by Jodles, Nov 19, 2010.
  1. Jodles
    Jodles
    13
    Nov 19, 2010
    Hi!
    I'm trying to derive the argument of H(jw) for hi and lo pass filters.
    So far I've gotten the following:
    for low pass:
    From the voltage dividor I've gotten: H(jw) = 1/ (1 + j(w/w_c)) (w_c = ang. cutoff freq.)
    Then I found the angle by converting it to polar form and I get:
    arg H(jw) = arctan (w / w_c)
    But to my knowledge, it should be H(jw) = - arctan(w/w_c). Where is this minus coming from?
    Same thing with hi pass. Following the same procedure as above, starting with H(jw) = 1 / (1-j( w_c / w ) ), I get:
    arg H(jw) = arctan (w_c / w)
    I also know I "should" be getting H(jw) 90 - arctan (w_c / w).
    I can see this by recognizing how the filters work and how the output voltage lags the input voltage. But I don't see how this happens mathematically?
    Any help would be much appreciated!
  2. barathbushan
    barathbushan
    223
    Sep 26, 2009
    step 1 ) factorise H(jw) = 1/ (1 + j(w/w_c))
    i mean multiply both numerator and denominator by 1 - j(w/w_c) , and then
    separate real and imaginary terms
    step 2) angle = tan (imaginary/real)
    step 3) its your homework
  3. Jodles
    Jodles
    13
    Nov 19, 2010
    Thanks! I tried that earlier but ended up with a huge equation. Will try again!:)
  4. Jodles
    Jodles
    13
    Nov 19, 2010
    Ok, I've now gotten the right answer for the lo pass. But for the hi pass filter, I get:
    1 / (1-j w_c/w) = (1+jw_c/w) / (1+w_c^2 /w^2), then separating these and taking the arctan of b/a, I get w_c /w as before. Where do I find the 90 - arctan w_c/w?
