find voltage across diode
jackorocko
Apr 4, 2010
1,284
Apr 4, 2010
1,284
is this your homework again?
I'll give you a hint, is the diode forward or reversed bias? Maybe you drew it wrong, maybe not.
davenn
14,261
14,261
:) Where did the smoke come from? :):)
haha .. our tinkerer will soon learn that electronics run on smoke and not electrons,
cuz once the smoke is let out things stop working
To the OP, you cannot wire a diode directly across a power supply forward biased, you have basically put a short circuit across the battery.
The diode is going to conduct at full current that is capable from the PSU and is going to expire in a flash.
