Find some high stability RTC.
Hi,all
I am with a design which need very high frequency stabality RTC(real
time clock). 0.8ppm with temprature range from -40C --85C. I only
found the maxim's ds3221 with 3.5ppm from -40C --85C. Any suggestion?
thx
P
Pooh Bear
Hi,all
thx
Use an ovened crystal ? This was always the choice for frequency accuracy
of old. Does anyone still do them ?
Just looked. IQD certainly did in 1995 ( old data book ). Offered up to
0.25ppm freq stability.
Graham
D
dalai lamah
Un bel giorno [email protected] digitò:
0.8 ppm in -40/+85 look *very* hard to achieve. You don't have to care
about the RTC, you need a very stable TCXO, or a OCXO.
R
Rene Tschaggelar
Hi,all
A customized OCXO will do the job. Customized since the
temperature range is non standard. You sure could use a
normal OCXO running at +75 Degrees or so. But if it did
run colder, you'd possibly save a lot of power.
Rene
R
René
Graham
GPS derived? Internet time server? Radio controlled clock..
Even 50 Hz (60Hz?) controlled clocks should have good long term
stability.
