find phasor current
Discussion in 'Electronics Homework Help' started by Ledwardz, Dec 24, 2010.
  1. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    Hi, we have been given exam papers to revise from with no solutions....... yes i know its stupid and means i don't know if what i am doing is right.
    ive attached the question and here is my answer
    4.46A with a phase angle of 30.38.
    but if im doing it wrong i need to know........
    my working is as follows:
    Vt = 25v to angle of 53 + 33v with no angle
    = 58v to angle 53
    The magnitude of impedance = 13 (square root of 5 +12 squared)
    the angle of impedance = 22.62 degrees. (arctan 5/12)
    then i = V/Z
    so i get 4.46 < 30.38 A
    if any one could confirm that id appreciate it. Thanks, Lee.
  2. barathbushan
    barathbushan
    223
    Sep 26, 2009
    The whole method of solving the problem is right and the calculation of IMPEDENCE is also right , but the voltage computation is absolutely
    wrong !!
    i wont re-solve the entire problem , but i will tell you that , you just cant add the voltage magnitudes and angles like you have done , as it is clearly shown here
    http://answers.yahoo.com/question/index?qid=20090421045522AAnABsZ
    so learn your complex algebra well , and you will be able to tackle such problems
  3. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    soo
    i should get Voltage = (58cos53 + j53sin53)
    and impedence = (13cos22.62 + j13sin22.62)
    then i got rid of sin n cos
    (34.9 + j46.3) / (12 + j5)
    then multiply by complex conjugate (12 - j5)
    which = 3.85 + j2.25
    magnitude = 4.46
    angle = 30.3
    so answer = 4.46 to angle of 30.3 A ???
  4. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    ahh crap i got same answer...... nm thats obviously wrong ill have another look. AHHHH.... i get it ha ha ha ha yeah okay u mean adding the voltages at the start is wrong h aha ha ha well i look like an idiot now. o well.
  5. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    okay ill try again
    voltage magnitude = 52V
    and angle = 22.6
    I think that should be right?
  6. barathbushan
    barathbushan
    223
    Sep 26, 2009
    no its wrong , let me give you the answer its
    52.63<24.15 volts
    one more method of solving the addition is converting both the voltages
    25<53 and 33<0
    to rectangular form , then add the real and imaginary parts
    after that re-convert them to the polar form
    use the above method is used if you have difficulty with polar form , but it's
    not a good way to solve , please go through basic complex algebra
  7. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    i really dont know where i am going wrong as far as i am aware adding in polar goes something like this. i tried using example but exchanged the sin and cos for their actual numbers so when i squared it was easier.
    =(25cos53 + j25sin53) + (33cos0)
    = 15.04.. + j 19.966.. + 33
    = 48.04.. + j19.966..
    then magnitude is square root of em squared
    n arctan for angle.
    have i got it all wrong? It seems near the answer, maybe i have just done something stupid?
  8. barathbushan
    barathbushan
    223
    Sep 26, 2009
    yes that's the answer just convert 48.04 + 19.996j into polar form , then you will get the right answer of 52.63<24.15 volts
    magnitude = sqrt (48.04^2 +19.996^2 )=52.02
    angle = tan-1(19.996/48.04) =22.56
    ie 52.02<22.56 (approx to my answer of 52.63<24.15 )
  9. Ledwardz
    Ledwardz
    43
    Dec 21, 2010
    Thanks! i appreciate the help.
