Find Amplifier Output
Discussion in 'Electronics Homework Help' started by Agonche, Jun 18, 2013.
  1. Agonche
    Agonche
    3
    Aug 23, 2012
    Hello there.
    I am preparing for an exam and solving random problems.
    I'm not sure if I solved this one correctly so I just need a confirmation.
    Find the output expression:
    [​IMG]
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    My solution for Vout is the same as yours. However, I do not understand your method. My method is to realize that the voltage difference between the op-amp inputs must be zero.
  3. Agonche
    Agonche
    3
    Aug 23, 2012
    OK, so the solution seems to be right.
    First I simplified the circuit (found Ve and Re).
    Then using Kirchhoff's laws I wrote equations for I1 and I2.
    I2=I1, and then just solve Vo.
    Thanks.
  4. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    At first I did not understand why you calculated Re since it is not relevant to the solution. But now I can see you don't use Re anywhere in your solution.
    Then I did not understand the marked paths labeled with circled '1' and '2' going from Vin1 to GND and from Vout to GND. That is still a mystery.
