T
The Real Andy
So after many months of assing about and pestering from the old man
(dad) I finally have a working prototype of my sinlge to three phase
variable speed drive up and running. The design uses an International
Rectifier IRAMX16UP60A IGBT module:
http://ec.irf.com/v6/en/US/adirect/ir?cmd=catProductDetailFrame&productID=IRAMX16UP60A
I have the output connected directly to the motor. PWM is around
20khz. Problem is, the motor feels to be getting quite hot, finger
test would put it at around 40-50degC. The module itself is supposed
to be able to cope with about junction temp of 150degC, i estimate it
to be at about 60-70degC running a 1/3hp motor at 60Hz.
The problem, i know nothing about how hot a 1/3hp 3phase motor should
be running at, this project is for my father, a retired engineer. I
can live with the module itself running at its current temp,
considering the relative lack of heatsinking. Nothing a bigger
heatsink and a fan cant handle.
My question is, should the output be filtered with a capacitor, or is
it ok to feed the raw PWM output straight into the motor? The output
looks very bad on the cro, but the noise induced into the ground lead
makes this hard to prove.
Please excuse my ignorance on this subject, but I really know very
little. Google has been very good to me so far, but I am struggling to
find an answer on this one.
Thanks.
Andy
BTW. I will do some proper temperature tests very soon!!
Thanks.
Andy
