Filling station
Discussion in 'Electronic Basics' started by moss, Feb 12, 2007.
  1. moss
    moss Guest
    hi, I was hoping somebody out there could give me some ideas on an
    automatic filling system that i'm trying to create.I need to fill 6
    plastic bottles (5 litres) in a small production line setup at home.I
    was thinking of sensors operating a bank of valves, but i'm not sure
    what sort of sensors etc.
    9
  2. Tom Biasi
    Tom Biasi Guest
    You could have the filler rod sleeved with a float that activated a
    microswitch at the desired level.
    Tom
  3. John Fields
    John Fields Guest
  4. ISTM this is usually done with a timer and a controlled flow rate.
  5. JeffM
    JeffM Guest
    If the fluid is opaque and the containers are not,
    you could also use a photoelectric system.
    I like Fields' *scales* notion.
    (Commonly used; QC weighs the product anyway.)
  6. Maxwell
    Maxwell Guest
    Five liters total or each bottle?
    Do you need to pump the material, or is it gravity feed?
    What is the viscosity of the material? Corrosive? For human consumption?
    Positive displacement rotary pump on a stepper, servo or timer. Could pump
    continious in a closed loop, and use a soleniod to fill by timer very fast.
    Single shot piston pump with adjustable precision stop on the stroke.
    Perhaps pump cylinder powered by an air cylinder.
