Hi all,
I am desperately looking for some help here and hoped someone might be able to clue me in on this.
I recently purchased a photo copy stand that has four high powered lights on it. These are the lights, here. There are two lights on each side of the table that run down to plugs for each. Those plugs run to a junction with a switch and a fuse for each side and from the junction, a single cord runs out to the wall. I am trying to figure out what amp the fuse would be. The fuse that was in it says 'Buss MDL 6' on one end and '120V SD' on the other, but there are plenty of 120V fuses out there in different amperage.
Included are pictures of the lamp and the fuse...
Thanks for any advice you can give.
Edit: I should have mentioned my knowledge of anything electrical falls somewhere between burnt toast and none at all...
