B
Boris Gjenero
I'm using a surplus VFD (vacuum fluorescent display) without any info:
http://www.sciplus.com/singleItem.cfm?terms=2391&cartLogFrom=Search
It's labeled: NEC FIP11AMW8 NO. 2 - 8 JAPAN
It is 16x multiplexed. The glass is about 11x5 cm and it has 12
14-segment characters, two 14 segment bar graphs, two 7-segment
characters and various indicators for use in a stereo system. Almost
everything is in the familiar greenish phosphor and there are a few
reddish indicators.
I'm giving it a 3 V peak-to-peak square wave for the filament,
centered around 3.2 volts and generally 20 V for the anodes and grids
and of course multiplexing. This works pretty well but I'd like to be
more certain about what I should really be giving it.
I'm wondering whether to boost the filament voltage. Now they're
almost unnoticeable in total darkness. If I take out a diode they
become noticeably reddish in total darkness with the display off but
are otherwise not really noticeable. Display brightness increases and
it's a bit more equal. Of course I can increase the anode voltage
but perhaps lower anode voltage means longer life.
I'm also wondering about the anode voltage. With the current filament
voltage brightness changes a lot up to 22 V or so and then not as much
as I increase towards 30V. 20V seems good for the greenish phosphor
but it seems like the red one needs more to light up well.
reddish indicators.
