Q
[email protected]
I want to make some io interface which can read/write 64 bitpatterns
from/to the LPT port. The FIFO must be synchronized
on clock signals TXC and RXC.
SENDING DATA TO LPT:
minimum 64bit memory (to store x datapatterns) FIFO System
=TXC=======>* byte1-8 (1) *======>TX 8*8bytes LPT PC PORT
* byte1-8 (2) *
* byte1-8 (3) *
DEVICE * byte1-8 (4) *
* byte1-8 (5) *
* byte1-8 (6) *
=TX=64BITS=>* byte1-8 (7) *
RECEIVING DATA TO LPT:
<RXC========* byte1-8 (1) *<=====>RX 8*8bytes LPT PC PORT
* byte1-8 (2) *
* byte1-8 (3) *
* byte1-8 (5) *
* byte1-8 (6) *
<RX=64BITS==* byte1-8 (7) *
The TXC and RXC is a 25kHz 10% duty cycle TTL block wave
Please help me out with info and partnumbers...
Kind regards, Geert De Coninck, Belgium
* byte1-8 (2) *
* byte1-8 (3) *
* byte1-8 (5) *
* byte1-8 (6) *
* byte1-8 (2) *
* byte1-8 (3) *
* byte1-8 (5) *
* byte1-8 (6) *
