FIDELITY CTV 1400TF
Discussion in 'Electronic Repair' started by HERCYBIRDC130, Jun 18, 2006.
  1. TV Picture is down to approx 10mm across the screen. Have deen told it is
    the "Frame Chip" that has gone. Can anyone tell me which is the "Frame
    Chip" so I can fix it?
    Mother Board has No 190-931317-P1.
    Many thanks
    Chris
  2. Inty XP
    Inty XP Guest
    In data Sun, 18 Jun 2006 22:57:45 +0200, HERCYBIRDC130
    This has a vertical\frame fault.
    number of chassis?
    see for an IC mounted on an heatsink, and eventually take a photo
  3. b
    b Guest
    HERCYBIRDC130 ha escrito:
    that is probably an ONWA chassis.
    trace the vertical yoke wires (yellow and brown usually) back to the
    pcb and look for an IC with more than 6 legs mounted on a heatsink
    (often an AN or tda prefix). Not usually expensive.
    I would only attempt this repair if
    A) you're good at soldering and B) know the dangers of working inside
    tvs even with no power.
    -B.
