Fiber Optic
Discussion in 'General Electronics Discussion' started by colum, Aug 22, 2013.
  1. colum
    colum
    137
    4
    Jul 25, 2013
    I rescued 2 large rolls of fiber optic cable, one roll had the ends still attached and one rolls optic ends were cut off, I wonder if anyone knows a way I could attach an end or use this cable in some other way, the glass wire is quite thick and when I remove the many coatings including the liquid coating the glass wire will not bend just break.
    If this is successful I will use it for laser transmission. Thanks for reading this..colum
  2. davenn
    davenn Moderator
    13,765
    1,920
    sounds interesting
    what do you mean by ends still attached ??
    show us a photo
  3. Harald Kapp
    11,012
    2,506
    What kind of fiber optic is it? Monomode or Multimode? Glas or plastic?
    You need to know that to make good use of the cable.
  4. colum
    colum
    137
    4
    Jul 25, 2013
    Hi Dave, Don't know how to post a photo yet but the ends are small optical lenses that probably enlarge or concentrate the beam and a mechanical coupling...colum
  5. colum
    colum
    137
    4
    Jul 25, 2013
    Hi Harald. Its single glass wire that is too thick to bend and is certainly glass and I understand that a cable that can transmit an image is called coherent but this cable must be a 100 ft so I doubt it can transmit an image..I wonder if theres anyway to cut the ends and leave a flat surface for polishing..colum
  6. davenn
    davenn Moderator
    13,765
    1,920
    posting images
    click on Go Advanced button below the text box
    then click on the Manage Attachments button
    A window will open up you will see some Browse buttons in the top right of that window
    [​IMG]
    click on the top one and find the file on your puter
    The file location will load into the field to the left of the browse button
    click on the Upload button
    the file name will appear
    just above the attachment key info line
    close that window and go back to the text box you are typing in
    finish off any text and save
    the file will show as a thumbnail at the bottom of your post
    there is another couple of steps to show the pic in the post like I have done here but lets just see your pic for a start
    keep the pic small .... less than ~ 100kB and 800 x 600 or smaller
    cheers
