FET relay configuration
Discussion in 'Electronic Design' started by tempus fugit, May 28, 2007.
  1. tempus fugit
    tempus fugit Guest
    Hey all;
    This is kind of picked up from the 'can I do this with a uProcessor' thread.
    Eeyore got talking about using JFETs as a replacement for relays. This is
    what I've come up with, but I'd be glad to know of a better way, since I
    have 4 effects to switch in and out of the signal path, thus putting a fair
    amount of noise and resistance in the path:
    bypass comp bypass flanger
    in
    o-----------------o----------------o ---------oo-------------o
    o ->|-+ o->|-+ | o->|-+ o->|-+
    etc
    | | | o | | o | o
    | |-----------|----o---| | o--------|----o
    ___________ ___________
    control v control v control v control v
    What do you think? There would be 2 more sets of 2 FETs for the remaining
    effects.
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
  2. D from BC
    D from BC Guest
    Ohhhhh the horror! :p
    Is that some sort of analog multiplexer?
    I think the only good application I've had for JFETS is for DC current
    sources..
    Maybe go mixer style with VCA's...
    D from BC
  3. whit3rd
    whit3rd Guest
    Probably the intention is to make a clickless switch (by filtering the
    control voltage signals). Yep, VCAs or transconductance
    amplifiers, like LM13700 and the late SSM2017, are the slick way
    to do this.
    Or CA3080; I see that's now obsolete. Pity, there were some nice
    uses for 'em. The newer designs (LT1228) seem like overperformers,
    far pricier and faster than I like.
  4. Marra
    Marra Guest
    Why not use the bog standard 4016 or 4066 bi-lateral switches?
    Cheap as chips !
    www.ckp-railways.talktalk.net/pcbcad21.htm
  5. D from BC
    D from BC Guest
    Long ago I heard of THAT Corp. VCA's..
    D from BC
