ferrite cores
Discussion in 'Home Power and Microgeneration' started by Peterthinking, Sep 21, 2003.
  1. Just for fun I was ripping an old monitor into as many pieces as I could
    (I have a few days off work and am bored)
    I noticed there are a few big chunks of ferrite material wrapped around the
    end of the tube....some in the coils too
    I want to know if this was crushed into a powder and formed (pressed) into
    a new shape with a binding agent (epoxy) would it make a good core for a
    home built genny?like a brake drum generator?
    they could be formed then have the coils wrapped around them.
    I saw the otherpower site use magnetite in their wood one
    http://www.otherpower.com/woodmill.html
    ...would ferrite be better?
  2. Ian Stirling
    Ian Stirling Guest
    No, it wouldn't really work very well.
    You'd be vastly beter off using a proper motor as a generator, if you want
    one.
    And old transformers are probably an easier source of magnetic material.
    http://inquisitor.i.am/ | mailto: | Ian Stirling.
    "The device every conquerer, yes, every altruistic liberator should be required
    to wear on his shield... is a little girl and her kitten, at ground zero"
    - Sir Dominic Flandry in Poul Andersons 'A Knight of Ghosts and Shadows'
