Ferguson TX100 chassis T.V
Discussion in 'Electronic Repair' started by M.Joshi, Jan 20, 2005.
  1. M.Joshi
    M.Joshi Guest
    Where should I start LOPT? I have checked all the usual things. How d
    you check a damaged capacitor with a multimeter with no capacito
    tester?
  2. Guest
    remove cap from cct.
    discharge it by bridging.
    connect multimeter set to relatively high resistance setting : red
    probe to cap. neg, black to cap +.
    meter should show: start as low resistance then rise steadily to a
    high one.
    Note this is a crude way of doing it but better than nothing without an
    ESR (effective series resistance) Meter. It may be easier just to
    replace suspect caps.
    -regards, Ben
