Femtofet soldering
Discussion in 'General Electronics Discussion' started by Karthik rajagopal, Jun 9, 2020.
  1. Karthik rajagopal
    Karthik rajagopal
    221
    7
    May 9, 2016
    Hi all,
    I recently ordered MOSFETs for my project from Texas instruments. After the arrival of the package, I noticed that I had wrongly ordered their ultra small mosfet package which they call as 'femtofet'. They are too small to solder and I am still finding a way to do that . Is there any suggestions that I could try out to solder wires to those pins. I have attached the dimension details and an image of the mosfet . IMG_20200609_194416.JPG IMG_20200609_195439.JPG
    Thanks in advance.
  2. bertus
    bertus Moderator
    689
    240
    Nov 8, 2019
    Hello,
    As the part is only 0.75 X 0.75 mm , you can not use them to solder wires to them.
    They are soldered directly to the PCB, likely using a hotplate.
    For better pictures, try to use the macro function of the phone.
    Here is an example of some SMD parts.
    The 1822 resistors are 2 mm and the diode is 3 mm:
    Bertus
  3. Karthik rajagopal
    Karthik rajagopal
    221
    7
    May 9, 2016
    Thanks for the reply. Since I don't have a hot air gun and the package does not have leads, is there any method to solder this on a pcb?
  4. bertus
    bertus Moderator
    689
    240
    Nov 8, 2019
    Hello,
    What does the datasheet say?
    It has likely a temperature diagram for a flow oven.
    Bertus
  5. Karthik rajagopal
    Karthik rajagopal
    221
    7
    May 9, 2016
    I don't think they have mentioned any temperature diagram for the reflow oven.
    This is the part no. :csd25501f3
    Is there any other way I can do it since I don't have access to any sophisticated equipments.
    I tried heating the traces of the pcb after applying solder on to the pad but successful destroyed both the pcb and the component. Will this method be worth a second try or am I doing it the wrong way?
  6. bertus
    bertus Moderator
    689
    240
    Nov 8, 2019
    Hello,
    Have a look at the attached PDF.
    Bertus
  7. Karthik rajagopal
    Karthik rajagopal
    221
    7
    May 9, 2016
    Thanks for sharing this . Is there any way I can do this reflow method at home ?
  8. bertus
    bertus Moderator
    689
    240
    Nov 8, 2019
    Karthik rajagopal and davenn like this.
