Feedback loops bug me
Discussion in 'Electronic Design' started by Chris Carlen, Aug 11, 2006.
  1. Chris Carlen
    Chris Carlen Guest
    Hi:
    I have a PLL loop which works. But I sit here looking at my LTspice AC
    analysis schematic and try to trace signals around it from the reference
    phase source into the PFD, to the feedback phase from the VCO (a motor
    in this case) and it's just so confusing.
    At DC, the thing has positive feedback! That is, due to the action of
    the phase error integrator (a 2nd order PLL), as well as the integration
    of frequency->phase which occurs in the VCO, a low frequency up wiggle
    into the + input of the PFD comes back from the motor as a down wiggle.
    But that goes into the - input of the PFD. So that would cause more
    up-ness at the output of the PFD than what arose from the original up
    wiggle that started the whole thingy.
    That means it has positive feedback.
    Only at the unity gain frequency of the open loop (f0) does it have
    negative feedback, and even then only with about 55 degrees of margin.
    That is what is so counter-intuitive. A loop can have positive feedback
    at a frequency where gain is very high, and yet be stable as long as at
    f0 it's phase is just not too close to positive feedback. In fact, with
    55 degrees of margin, it's close to positive feedback than negative.
    Then this is even more funny: A loop can be stable with 90 degrees
    phase. What is that? Half way to negative feedback, or halfway to
    positive feedback?
    Ugh!
    Good day!
    ________________________________________
    Christopher R. Carlen
    Principal Laser&Electronics Technologist
    Sandia National Laboratories CA USA
    NOTE, delete texts: "RemoveThis" and
    "BOGUS" from email address to reply.
  2. Jim Thompson
    Jim Thompson Guest
    Sounds like you are deluding yourself ;-)
    ...Jim Thompson
  3. John Larkin
    John Larkin Guest
    Positive feedback will latch! Maybe the real thing locks on the
    opposite clock phase from the one you're simulating. Lots of pll's
    will just slip a half cycle if you flip the loop gain polarity.
    John
  4. Jim Thompson
    Jim Thompson Guest
    Yep, an EXOR or multiplier-type phase detector will do that.
    ...Jim Thompson
  5. Tim Wescott
    Tim Wescott Guest
    Tch tch tch. You're trying to think rationally about infinities,
    without doing all the math.
    In the frequency domain, at DC, the phase shift is undefined. Why?
    Because the gain is infinite. You can only discover the phase shift as
    you _approach_ DC.
    So you have to toss the frequency domain out the window for this thought
    experiment (but not for analyzing the loop). To understand things you
    have to go back home, to the time domain where we all live and things
    make sense.
    Here, if the phase of the motor lags a bit the integrator in your loop
    filter will act to drive the motor harder, which will spin faster, which
    will make it accumulate phase faster -- so indeed you have negative
    feedback because a slow motor tends to speed up.
    If you try to go forward at this point you immediately run into problems
    because of the lag caused by the double integrator. Trying to describe
    the system behavior, and discovering stability, entirely in the time
    domain is fiendishly difficult. It can be done, in fact it must be done
    if you system is severely nonlinear, but it isn't pretty.
    So to actually discover stability you use the frequency domain, and
    there you find lots of things that are counter intuitive. There are
    several ways you can cope with this problem:
    1. Become a digital system designer.
    2. Enter a convent (or a monastery if you're boring).
    3. Get an MBA, and become a pointy-haired boss.
    4. Just do the math in the frequency domain, and trust it.
    4a. Do the math in the frequency domain, and insist on doing it until
    it all becomes intuitive. Internally, this means that those
    neurons in your brain that _know_ that it's all BS will have to
    be killed off before you can proceed -- this is why good
    engineering students drink so much beer.
    Keep thinking on this, tell yourself it doesn't matter, and DRINK MORE BEER!
    Or consider that at 55 degrees of phase margin your 'positive' feedback
    is 1/2 or so -- which means that after it rolls through the loop once
    it's 1/4, then 1/8, then 1/16, etc.
    But wait! A loop can be _unstable_ with 90 degrees phase shift at unity
    gain -- and it can be either +90 or -90 degrees (I just know someone is
    going to challenge me on that, and I'll have to fake up some bizarre
    loops, but it's true -- really).
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    "Applied Control Theory for Embedded Systems" came out in April.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  6. Tim Wescott
    Tim Wescott Guest
    Do this thought experiment (and consider my previous post, and how much
    beer you have on hand).
    Replace your integrators with really, really low-pass filters. At all
    but the lowest of frequencies they'll each cause -90 degrees of phase
    shift, and your feedback will be positive. Right at DC, however,
    they'll have 0 degrees phase shift and your feedback will be negative
    (and very large), just like you want.
    -- snip --
    Tim Wescott
  7. Chris Carlen
    Chris Carlen Guest
    No. It works exactly as it should. It uses a 3-state PFD. There is
    negative feedback in the sense that observation shows the following:
    1. If reference phase increases
    2. output of PFD increases
    3. output of compentation network (VCO command voltage) increases
    4. VCO therefore speeds up
    5. phase error between VCO and ref therefore decreases
    6. phase of VCO goes into - input of PFD, so
    7. PFD output decreases
    8. When VCO has caught up to ref, then PFD output returns to zero
    What is confusing is that in the open loop AC analysis (1) there is 180
    degrees of phase shift to the - input of the PFD. That would seem to be
    positive feedback.
    The 180 comes from the two integrating poles (1/s) from the phase error
    integrator and the VCO.
    Note:
    1. That means the - input to the PFD is grounded, and the output of the
    VCO is where the frequency response is being measured. This is an
    ***AC*** model so the output of the VCO means Kvco/s .
    Good day!
  8. CC
    CC Guest
    Which is 180 degrees, with ideal components.
    Yes, that is obvious. Without thinking about phase shifts, inspection
    of the loop reveals negative feadback. The confusion arises in why the
    AC shows 180 degrees.
    Yeah, that's what I mean.
    Adding your stuff from the later post:
    "Do this thought experiment (and consider my previous post, and how much
    (and very large), just like you want. "
    Yeah, certainly it actually works out that way since the integrator
    fades out as the opamp gain is finite.
    I wouldn't mind seeing such a loop.
    I think I have to progress to the root-locus method of analysis.
    Good day!
  9. Consider yourself challanged!
    I can think of an example where this is true, but its a cheat.
    Consider a response where the gain falls down past unity, hitting unity
    at 90 degrees. Then have the gain increase back up again to some value
    above unity. Then have the gain fall off at a >= second order rate back
    through a final unity gain. This will be unstable. However, the 1st
    x-ing is a red herring. Stability only cares about the final x-ing, not
    intermediate ones.
    Other than that, there is no realistsic way for the system to be
    unstable if gain < 1 at phase < 180. The converse is not true. Its quite
    easy to construct systems with gain > 1 at 180 deg (net positive fb)
    that are quite stable.
    Of course, one has to have a correct value of small signal loop gain, at
    all operating conditions. In non-linear systems, the small signal gain
    at one output value, is not the same as at another output value. For
    example, the collecter base capacitance of a transister is a function of
    collecter base voltage. This can cause different phase shifts at
    different output voltages, hence intability at only some values of
    output. One needs to construct ac gains over a range of values, even
    this, technically isnt enough. In principle, its possible for, say an
    amp, to be stable ac analysis wise when the amp is say, in clip and out
    of clip, but not if transferring between those two regions.
    The only way to verify stability is to actually do many transient runs
    in spice (with good models). AC analysis or hand calculations are just
    not sufficient for anything but trivial circuits.
    Kevin Aylward B.Sc.
    http://www.anasoft.co.uk
    "There are none more ignorant and useless,than they that seek answers
    on their knees, with their eyes closed"
  10. CC
    CC Guest
    Isn't this almost a case of effectively separate circuits? I mean that
    say in a transistor stage, if there is a unity gain point at some
    frequency where the crossing phase is <180, and that is the intended
    region of operation, then that circuit can be functional even though in
    a higher frequency range the gain again pops up over unity, and crosses
    again with oscillatory conditions. Hence a parasitic oscillation in a
    system that otherwise appears to be working normally. Some situations
    can tolerate this without it even degrading circuit performance in the
    region of interest, while others display peculiar anomalies such as
    unexplained drifts, etc.
    What exactly are the criteria for stability? In my not-formally derived
    understanding (a lot of which came from AoE's PLL and opamp
    discussions) negative FB at DC and <180 phase at f0 are the only essentials.
    Is this correct?
    However, I suppose a more general statement has to include
    considerations of matters such as right plane poles and zeros, which if
    present might complicate matters. I have some interest in eventually
    dealing with this since I am aware of the fact that SMPS topologies can
    have right plane poles/zeros, and so I suppose frequency domain analysis
    isn't quite enough for these.
    Even then, you still need to build the actual hardware and see what
    other shenanigans go wrong.
    Good day!
  11. PeteS
    PeteS Guest
    I would say this is a matter of properly modeling the stage, rather
    than separate circuits.
    We can ignore certain properties of devices if we constrain the
    analysis, but you can't really see what contraints (loop frequency max,
    for example) to apply until you know what demons lurk out there. There
    are certainly good rules of thumb, but they remain that ;)
    I have had a particular circuit (SMPS, in this case) that was unstable
    at 150 degrees (30 degrees margin), but that was an unusual case.
    (Current mode supply with loads ranging from zero to 15 amps with fast
    transients).
    For most of them, it can be - it depends on the loop. If there are
    severe non-linearities involved, no.
    I made myself a nice little program that plots phase v. load at
    arbitrary frequencies and then plots it as a rolling movement. Very
    handy to see just where the phase becomes an issue. Of course, with
    very fine-grained discrete frequencies, it can take a while to run ;)
    Many threads here have noted that layout is a critical issue in loops
    because it's easy to introduce an unintended pole or zero by the
    artifice of a track being too close to a high current plane. Myriad of
    these examples abound.
    Remember : Drink more beer!
    Cheers
    PeteS
  12. As far as it goes, yes, but it doesn't go far enough. The Nyquist
    Diagram is a polar plot of gain and phase. The crunch point is at (-1,
    0) which represents unity gain and 180 phase. The plot must not
    *enclose* this point, because if it does, the plot will pass through it
    during switch-on, resulting in oscillation that may or may not be
    sustained.
    As Kevin A said, there are other cases. if you drive the circuit into
    non-linearity, its gain goes down, perhaps to zero, over part of a
    cycle. This also may make the plot pass transiently through (-1, 0),
    resulting in parasitic oscillation, which, again, may be sustained or
    may stop.
    This is a different approach; don't try to mix them up. Of course, they
    are related, but that isn't elementary. Poles and zeroes live on a
    different plane than the Nyquist diagram, even though both of them have
    real and imaginary axes.
  13. Ken Smith
    Ken Smith Guest
    If this what you really have, the phase shift is 179.9999 degrees not 180
    degrees and it will ring like a bell. The integrator's imperfection is
    all that is making it stable. Is there a resistor in series with the
    capacitor?
  14. Ken Smith
    Ken Smith Guest
    What matters is the phase shift at the highest frequency where you have
    unity gain. A system that includes a delay line can cycle above and below
    unity gain many times before it finally stays below.
    Also: You have to be careful about not dropping 360 degrees from the
    phase shift. If a circuit is already an oscillator, enclosing it in a
    feedback loop may not stop the oscillation. If you drop the 360 degrees
    in the Bode plot, it can look like it should when it won't.
  15. CC
    CC Guest
    Yes. And a lead-lag network. The transient response is quite good.
    There is about 3dB of gain peaking in the closed-loop.
    Here's the circuit AC and transient models in LTspice form:
    http://web.newsguy.com/crcarl/LTspice/motor-pll/pll-200w-4Hz+subs.zip
  16. Ken Smith
    Ken Smith Guest
    That makes it just about ideal. In time domain, there should be nearly no
    overshoot.
    I left that for the CC to myself.
    I'll take a look later.
  17. Genome
    Genome Guest
    Yes....
    Tell you what, if I had the state of mind that you have at the moment.....
    and I do and I have... that sort of thing would stress me out as well.
    Obviously the clever people around here will tell you how to reduce your
    circuit to a purely linear one and then let you know how to look at the
    thing that is worrying you and also show how it should not really.
    DNA
  18. Not exactly. This will guarantee stability, but it is not a necessary
    condition for stability.
    The fundermental idea to stability is is there a pole in the right hand
    plane. That is for:
    Av(s) = ()()().../()()()...
    where () are 1+k.S terms, k different for each pole. e.g. (1+RC.S) terms
    All small signal stability analysis is an attempt to find out where the
    demominater goes to zero for a particular value of S. If it does, the
    system is unstable. The basic isue is that finding the roots equatons is
    difficult. The demominator of a system is usually express as a power
    series, not in factored form.
    Nyquist plots and bode plotes are just methods to graphically try and
    determine where the roots of the denominator of the loop gain is.
    For Nyquist plots, "it can be shown" that the number of net
    encirclements of the -1 point tells you whether or not there is a pole.
    The summary is that stability effectivly only depends on the gain and
    phase at the last zero x-ing point. This means that intermediate
    frequencies can have gain and positive feedback and still be stable. If
    the phase does go to net 0 deg (180 in NF systems) then the system is
    "conditionally" stable. That is, it is conditioned on the gain. If the
    gain were to fall, the system could go unstable, e.g. vacuum tubes when
    warming up. Note that in RF, conditionally stable might well mean stable
    independent of load and source impedances, which is a different meaning.
    Yes and no. RHZ cause extra phase shift, but as far as the analysis is
    concerned, its all in the wash. You need to to transient sims because
    real systems are always non-linear.
    Kevin Aylward B.Sc.
  19. Slip there, Kevin. That's 'unconditionally stable'.
  20. joseph2k
    joseph2k Guest
    No, he just needs to "go back to school" and take a few courses in control
    theory.
