FBT for KDS monitor
Discussion in 'Electronic Repair' started by Joachim, Nov 13, 2005.
  1. Joachim
    Joachim Guest
    My KDS monitor has a sparking FBTransformer. I tried to fix it with som
    plastic spray and it worked for a while. But now it started again.
    I think I need a new one.
    Somebody knows where I can find one?
    I wrote to www.kdsusa.com and they say I have to send it to one o
    their stores. That is something I don't want to do. From here in Cost
    Rica.
    It is a 17" VS-7i model
    Thank for your help
    Joachi
  2. James Sweet
    James Sweet Guest
    Try some clear silicone caulk, lay it on nice and thick in several
    thinner coats over the spot that's sparking.
  3. Joachim
    Joachim Guest
    Thank you for the tip but I think there is bad connection inside of th
    FBT. The cable for the anode is lose inside of the FBT and this wil
    sooner or later burn the cable.
    Where can I find such a FBT?
    Joachi
  4. James Sweet
    James Sweet Guest
    Not sure, did you try a google search? Some FBTs can be difficult to find.
    If the cable is loose you might have luck cutting into the plastic where
    it attaches and soldering it in then caulking over.
