favorite/best style of potentiometer?
Discussion in 'Electronic Design' started by Michael, Jul 20, 2003.
  1. Michael
    Michael Guest
    Hi - I was just wondering what you think the best style of potentiometer is
    for through hole mounting or surface mount? I have little experience with
    the various styles - but so far - my favorite was a kind that came in a
    small blue box with a little screw on the top. Are some designs better for
    some reason? The reason I ask is I'm ordering up parts (from Digi Key - if
    it matters) on Monday and I can't quite decide on what kind of
    potentiometer I want to use. Any advice? Thanks so much!
  2. John Larkin
    John Larkin Guest
    The multiturns don't generally have better resolution than the
    singles; their dinky screw mechanisms have a lot of backlash. I like
    the 4 mm surface-mount things.
    John
  3. Like this one?
    http://www.bourns.com/2/pdfs//3314.pdf
    They claim 3% CRV vs. 1% on the usual 3/8" square pots. Are the wipers
    polyfurcated (if that's a real word)?
    For low end applications, I've had good luck with the single turn 6mm
    cermet open ("dustproof") types. They are < 1/10 the price.
    Best regards,
    Spehro Pefhany
  4. Bill Sloman
    Bill Sloman Guest
    The 3/8" square multiturn potentiometers are horrible. If you can find
    room for the 19mm long trimming potentiometers with the adjusting
    screw at one end you will find that that they are easier to set and
    have much less back-lash when you over-shoot the desired value.
    The variant with the clear top, that lets you see when you have
    screwed the wiper up to one end or the other, is even nicer, and not
    much dearer.
  5. gene ohara
    gene ohara Guest
    bill,
    Would you please post the mfr(s) of the one your like.
    gene
