When the picture suddenly goes on a t.v., what is it usually due to?
Operation of the power switch. Are you thinking of fixing a TV? If so, you will be concerned with why yours is broken, not common cases. That said, a common failure is breakdown of the flyback HV winding, a fairly expensive part to replace.
When the picture suddenly goes on a t.v., what is it usually I don't think this could be it, as there is sound, hence the power switch must be delivering current. Are there cheap generic replacements? What is expensive 10 Pounds or 100 Pounds ?
Hmmm. I almost wrote that more symptoms would They may have become generic lately. When I was last looking into it. the transformers tended to have so many taps, different output voltages, and primary inductance values, that they were all different. If you really want to diagnose your TV's problem, it would help to describe more of what you can see, especially with different input stimulii if they vary the result. For example, how long after turn-on before the picture "goes". What does "goes" look like? Does it ever come back? Is there a change in the sound emitted? Any odd smells? What can you see when you open the cover and shine a light on the circuit board(s)? Do you have any instruments to apply to the task? Are you willing to purchase the schematic for the set?
Larry you should just direct people to the proper newsgroup: where they will need to know the brand, model and all the symptoms.
That would depend on the OP's desire and resources, would it not? I doubt you know enough to gauge either at this point. Mr. Terrell's suggestion to take the issue to is more appropriate under the circumstances, IMHO. Followups set accordingly.
Again! It is blatantly apparent you do not have the technical quality to attempt this type of repair, take the flippin thing to a professional servicer. For YOUR PERSONAL SAFETY!!
First of all, I am not the one with the bad television. I simply pointed out that was not the place to ask about TV repair and told the OP to ask his questions on and to give the make, model and symptoms in the request. As far as TV repair I was working in a TV shop in the mid '60s at the age of 13. I moved on to broadcast, Radar CATV and aerospace electronics. I have done things the average tech will never do and I was taught electrical safety when I was 13. I am now 100% disabled for a number of reasons but I still know how to do the work. Your silly little rant makes you look bad and doesn't reflect well on TV techs in general.
Sorry for omitting all the info, but the reason is that the tv has been chucked away, still I wanted to know what it could have been. The engineer had one look at it and said it was not worth fixing, he didn't even open it, seems he new what it was straight away. It was a 25" Panasonic, but I don't know what model it was. One day we switched it on with the remote and only the sound started, i.e. no picture. That's it, no picture was ever visible from then on, the screen was exactly as if the unit was off, no partial brightness or near the corners, just absolutly dead, as if no power was on. But this is all academic , so feel free not to waste your time too much... tnx.
