M
M.Joshi
A few days ago, our computer suddenly started to emit black smoke an
stopped working.
Upon further inspection, the power supply had a large hole blow
through the case which seemed as though something had exploded and
black 'gunky' substance leaking from it.
We replaced the power supply and tried testing the motherboard but onl
the fans power up. I have checked that both power connectors ar
connected and also tried removing all peripherals and cards.
Nothing appears on the screen and the motherboard does not even get a
far as the P.O.S.T?
Looking at the electrolytic capacitors near the P4 power connector,
few of them seem 'puffed up' at the top, with a powder substanc
leaking from the top.
I tested the capacitors with the continuity setting on a multi-mete
and two of them showed as a short circuit. I know testing in circui
will not give a conclusive reading so I will de-solder just to mak
sure first.
I am wondering whether the short-circuited capacitor(s) on th
motherboard near the P4 connector caused the power supply to becom
damaged?
Does the P4 power supply affect the motherboard's startup routine?
I thought the BIOS would be powered from the main power connector an
that the P4 power supply is just for the processor?
The motherboard is a Gigabyte P4 Socket 478 GA-8IRML.
I remember reading about Gigabyte having a problem with faulty powe
supply decoupling capacitors a few years back
stopped working.
far as the P.O.S.T?
sure first.
damaged?
