fast switching circuit/spice sim
Discussion in 'Electronic Design' started by steve, Sep 30, 2005.
  1. steve
    steve Guest
    I'm trying to create a high speed enable/disable control for an
    analogue signal. I found some SD5400 DMOS ICs (quad DMOS N-type FETs)
    from Linear Systems that switch quickly (2ns) and I've got a simple
    spice circuit to test this.
    The test circuit is: a 2V p-p (with 1V DC offset) sinewave applied to
    the drain, a DC control voltage applied to the gate, and a 1MOhm load
    (modelling the input impedance of a buffer) at the source, ie:
    Vsin in GND SIN(1 1 1000k 0 0)
    M1 in gate out GND sd5400cy
    Vdc gate GND DC 1
    R1 out GND 1000k
    However, the circuit doesn't simulate as expected. With a Vg = 1V, the
    FET is off and the output is pulled to ground via the load resistance.
    This is as expected.
    But when I apply a 5V gate voltage (so that the gate-source voltage is
    always greater than the Vth=1.2V of the FET), it turns on but the
    output looks distorted, as shown here:
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-5V.pdf
    Shouldn't the output be following the input? The FET is operating as a
    SPST switch, and its Rds(on) is insignificant in comparison to the
    load.
    Also, I've found that increasing Vg decreases the deviation of the
    output from the input, ie with Vg=15V and Vg=100V:
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-15V.pdf
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-100V.pdf
    For completeness, Vg=1V is also included:
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-1V.pdf
    Can anyone give me any hints as to what is going on here?
    Is there something wrong with my idea of using a FET as a switch
    directly? Am I missing anything?
    Cheers,
    Steve
  2. Jim Thompson
    Jim Thompson Guest
    Looks like your device needs at least 10V VGS to be "ON"... note _VGS_
    ...Jim Thompson
  3. steve
    steve Guest
    Hi Jim,
    The datasheet specifys Vgs(th)(max) as 1.5V - are you saying that the
    transition region of the device from being off to being on stretches
    from 1.5V to 10V? Or have I misunderstood the datasheet, and does
    Vth=10V, not 1.5V?
    Cheers,
    Steve
  4. Jim Thompson
    Jim Thompson Guest
    Threshold (Vgs(th) or simply Vth) means just that, THRESHOLD where
    current just begins, series R drops as Vgs increases.
    Win can provide more detail... he's the expert around here on discrete
    MOSFET's (I design chips... I very rarely get flux on my fingers :)
    ...Jim Thompson
  5. Joerg
    Joerg Guest
    Hello Jim,
    They are usually happy with 5V Vgs and actually spec'd for it if you can
    take 75 ohms. For under 50 ohms it needs to be 10V. But yes, it has to
    be Vgs so the gate voltage need to be in addition of whatever the source
    is riding at.
    Steve: Don't forget to connect the substrate when you try it out. It's
    separate on these.
    Regards, Joerg
  6. John Perry
    John Perry Guest
    Steve, you need to look at page 2 of the datasheet, in the rows labelled
    "Drain-Source On-Resistance" There you'll see the details of Joerg's
    description. Now, if your gate voltage is high enough above the highest
    signal voltage, the fet remains low-resistance.
    In your 5v gate plot, however, the peaks of the signal cause the source
    voltage to approach the gate voltage so that the fet resistance rises
    high enough to change the signal going to your output. You don't say
    what your circuit is, but your output waveform is about right for this
    effect.
    How did you manage to get the fets to survive a 100V gate voltage? They
    should all have fried instantly (p. 2, absolute maximum says +30, -25).
    Are all your fets shorted now? You should check drain-source
    resistance with Vgs = 0. They're probably dead.
    John Perry
  7. steve
    steve Guest
    I've re-run the simulations to see whether this is the case. First, I
    tried with Vg=7V, so that Vgs never drops below 5V. The results are
    here:
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-7V.pdf
    The output looks a lot better than with Vg=5V, but it's still not
    perfect - the amplitude of the output has decreased relative to the
    input, and there is a non-linearity and a phase offset.
    I also tried with Vg as a 2Vpp sinewave at a 6V offset - so that Vgs is
    always 5V, ie:
    Vdc gate GND SIN(6 1 1000k 0 0)
    The results are shown here:
    http://www.teamlinux.org.uk/steve/spice/switch_Vg-1mhz-6Voffset.pdf
    It's better than the Vg=7V case, but there are still problems - mainly
    with the amplitude.
    The FET has a Rds(on) = 70 Ohm, and the load is 1MOhm Also, the maximum
    Vin as seen in the results from applying a 1mhz sinewave on Vg is
    1.9995V. So a potential divider effect would be expected, and the
    maximum Vout should be 1.99936V.
    However, the maximum Vout as measured in the second set of results
    above is actually 1.8303V. For this to be the case, it must be dropping
    169.2mV across the FET, which means the FET Rds(on) must be 92.44kOhm,
    when Vgs=5V. This can't be correct.
    So I'm still not sure about what is going on. Any ideas?
    Thanks to everyone for their replys,
    Steve
  8. Jim Thompson
    Jim Thompson Guest
    Steve, If you want to get fancy, you can create a _nearly_ constant
    Ron by adding the signal to a your control voltage with an OpAmp and
    applying the sum to the gate, producing a constant Vgs.
    ...Jim Thompson
  9. Joerg
    Joerg Guest
    Hello Jim,
    But at 2nsec the opamp might require a call to the local utility before
    turning it on, and maybe a 2nd mortgage ;-)
    Regards, Joerg
  10. Joerg
    Joerg Guest
    Hello Steve,
    That doesn't look too bad. You'll need more Vgs to reduce RDSon modulation.
    That plot doesn't look bad at all.
    Look at what the capacitive load is, mostly to the substrate. At 1MHz
    that does matter, depending on your source impedance.
    Quite frankly my faith in SPICE when it comes to simulating FETs is a
    bit limited. I usually go by my "paper computer" and a good scope.
    While I used to be a big fan of the SD5400 my usage of them in designs
    has fizzled. The price increases are the main reason, lack of stock at
    some suppliers is another concern I have. There are other ways to switch
    a signal path fast. One is a diode array and a toroid transformer. Since
    quad arrays are often in the "boutique part" category, expensive and
    hard to procure I often squeeze by with pairs. Those cost pennies.
    Then there are lots of monolithic switches for wireless gear. Look under
    T/R switches and diversity switches.
    Regards, Joerg
  11. Jim Thompson
    Jim Thompson Guest
    Details, Details ;-)
    ...Jim Thompson
  12. Joerg
    Joerg Guest
    Hello Jim,
    That's what somebody said to me when using their pool heater in winter.
    Until the propane bill arrived, that is.
    Your idea can be implemented cheaply though. Just use a 1:1 toroid
    transformer and stack the secondary in series with the gate control source.
    Regards, Joerg
  13. Jim Thompson
    Jim Thompson Guest
    Yep, or use current drive.
    Come to think of it I used transformer drive on the Hubble, with DC
    restoration games so I could PWM. That was BC&S (before computers and
    simulators), I'll see if I have a paper copy somewhere.
    ...Jim Thompson
