Faraday's Law
Discussion in 'Electronic Design' started by Brent, Apr 4, 2004.
  1. Brent
    Brent Guest
    I am trying to design AC magnetic field detector, to detect a signal of
    75KHz from a wire loop. For a maximum efficiency I need to know how to
    design the coil for its resonance. I have the formula (Faraday's Law on
    Induction?),
    fo=29.85(h/d)1/5 divided by nd. My question is how to associate the
    variables of the formula. How many turns wire do I make, what diameter &
    what height. Also do I need a ferrite core, or a nonmagnetic core. Should
    I incorporate a capacitor into my circuit, but what size?
    Any help would be appreciated,
    Brent
  2. ddwyer
    ddwyer Guest
    If a single frequency then resonate the coil with a capacitor.
    If broad band then terminate the coil in an a voltage amplifier..
    I didithis latter years ago to measure magnetic fields from power lines
    and electric cooker etc.
  3. Brent
    Brent Guest
    How do I calculate the size of capacitor that I need?
    Brent
  4. the resonance frequency is omega=1/sqrt(L*C)
    A few tries are usually much simpler, as
    calculating the selfinductance of your coil is
    not trivial.
    Rene
