T
Tony Ramone
Hi all, I tried posting this back in my original thread, but I can't
for some reason (maybe it's too old or something), which is why I'm
pasting the original message in here, along with my follow up
question. Hope this isn't a horrible breach of usenetiquette...
I know it's been many months since I last posted on this, but
I just thought I'd check with you guys one last time before consigning
this TV to the dump.
Having read all your posts, and the FAQ, I looked around the board for
any cracks, and lo and behold, there was quite a sizeable one running
close to what I assume is the flyback transformer. And sure enough it
was running right through a fairly big track.
So I fixed the crack, then ran some solder and a thin wire along the
broken track. I checked it with my multimeter to make sure I had a
good connection between either end.
The thing is, it's still not working, and I noticed that one of the
smaller components near the transformer looks a little burnt (or at
least brown - could just be flux i suppose) on the underside (I'll
have to check again later which part it was - I can't find the piece
of paper that I had written it down on right now), and I guess it
could be that, or else maybe the transformer itself is just fucked.
If that's the case is it worth my while trying to fix it at all
(bearing in mind that while I do know how to solder and read circuit,
I don't really know what's going on on that particular board ).
I've already gotten a replacement, but I figured if this one would be
an easy fix I'd keep it for the spare room, but if not, then so be
it...
Thanks again for all your patience.
Ant
(and now the follow up):Thanks, I hadn't seen that, sorry. And thanks for all the tips
everyone else.
it...
Ant
