Fake Square D Circuit Breakers (RECALL)
Discussion in 'Electrical Engineering' started by RFI-EMI-GUY, May 29, 2008.
  1. RFI-EMI-GUY
    RFI-EMI-GUY Guest
  2. bud--
    bud-- Guest
    Thanks Joe.
    Being paranoid, and since the source is not the CPSC, I looked at the
    CPSC site and found the following recalls of apparently the same
    counterfeit SquareD breakers:
    5-2008
    Specialty Lamp International of Deerfield Beach, Fla. (as above)
    371,000 breakers
    http://www.cpsc.gov/cpscpub/prerel/prhtml08/08286.html
    12-2007
    North American Breaker Co. Inc. (NABCO), of Burbank, Calif.
    50,000 breakers
    http://www.cpsc.gov/cpscpub/prerel/prhtml08/08151.html
    10-2007
    Connecticut Electric & Switch Mfg. Co. (Connecticut Electric), of
    Puyallup, Wash
    64,000 breakers
    http://www.cpsc.gov/cpscpub/prerel/prhtml08/08054.html
    11-2006
    Scott Electric Co. Inc., of Greensburg, Pa
    30,000 breakers
    http://www.cpsc.gov/cpscpub/prerel/prhtml07/07036.html
    Crossposted to alt.home.repair
  3. RBM
    RBM Guest
    Bud, has there been any determination that these counterfeit, breakers are
    not made to the same specs as any other QO?
  4. dpb
    dpb Guest
    RBM wrote:
    No non-counterfeit recalls are there?
  5. RBM
    RBM Guest
  6. dpb
    dpb Guest
    Then how did they get a recall for failure to trip? If there were no
    instances of failing to trip?
    I can see making them retract them as counterfeits but that's not the
    baliwick of CPSC; that would be a legal thingie as near as I can tell.
    And, of course, they could well be "made to the same spec's" but that's
    not _quite_ the same thing as performing to the same spec.
  7. RBM
    RBM Guest
    OK, that's not what I heard. All I heard was that there were counterfeits
    that were being recalled, once identified, but nothing about failing to trip
  8. dpb
    dpb Guest
    RBM wrote:
    I hadn't "heard" anything but that's the first sentence of the link in
    the earlier posting...
  9. RBM
    RBM Guest
    Sure, now you're telling me I should read the links!!! I saw this
    yesterday, and as so much crap comes across my screen, I didn't pay too much
    attention to it
  10. dpb
    dpb Guest
    Well, if you're going to pay enough attention to ask questions...
  11. There have been warnings in the UK about counterfeits being found
    in other parts of Europe (but not as yet in the UK, AFAIK). A picture
    in a trade magazine shows one of them opened up. There are no overcurrent
    parts inside, and the toggle is just a plain switch.
  12. So, a perverse thought crosses one's mind: would replacing one's
    breakers with toggle switches be the equivalent of putting pennies in
    fuse sockets in the olden days?
  13. Guest
    | In article <483f1b7a$0$15166$>,
    |>> RBM wrote:
    |>>>>> are not made to the same specs as any other QO?
    |>>>> --I read that there weren't any incidents with the counterfeit breakers,
    |>>>> so I'm wondering if they are not in fact, the same
    How many people ever test the overcurrent aspect, anyway? I'm guessing one
    of these must have failed somewhere somehow to have gotten noticed.
  14. Guest
    | On 5/30/2008 6:49 AM Andrew Gabriel spake thus:
    Yes. BTW, they do make them ... switches that replace circuit breakers.
    If you need a lot of switches in a circumstance where you don't need the
    individual overcurrent protection, and need it in a more compact space
    than could be had with a bunch of 2x4 boxes, then this might be the thing.
    Imagine if you have a need to individually switch on and off 80 different
    7 watt lights. Would you put in 10 sets of 4-gang boxes with duplex switches
    in each, or put in an 84-slot panel and 80 switches? The latter might cost
    more due to the big box. The latter might not fit so well.
    I don't recall if the breakers are cheaper than switches, but perhaps the
    economy of scale of production for breakers could do that.
  15. AFAIK, they were discovered by manufacturers investigating how
    their products were turning up on the market too cheaply and
    undercutting the official distributors.
  16. Guest
    | In article <>,
    | writes:
    Ah, that would do it, too.
  17. James Sweet
    James Sweet Guest
    My heat pump has a switch in circuit breaker format in the disconnect
    box on the side of the house. A breaker isn't necessary out there, as
    the branch is protected in the main panel and nothing else is on it.
  18. Roy
    Roy Guest
    In alt.engineering.electrical Andrew Gabriel
    |       writes:
    UK about counterfeits being found | in other parts of Europe (but not as
    yet in the UK, AFAIK). A picture | in a trade magazine shows one of them
    opened up. There are no overcurrent | parts inside, and the toggle is
    one of these must have failed somewhere somehow to have gotten noticed.
    | AFAIK, they were discovered by manufacturers investigating how | their
    products were turning up on the market too cheaply and | undercutting
    |WARNING: Due to extreme spam,
    snip<
    I read that other post where it exploded
    ~ Ouch ~ It would seem Top Name Brand Manufacturers don't (shouldn't)
    farm out too much work for a reason.......then again....who knows maybe
    I've installed a few without knowing it was a knock off., They all seem
    so funny looking at times, though I try to by always from reputable
    supply houses and such };(
    They should've branded & licensed them "Electriv" ®™ and sold them
    as thus };) I'll be expecting royalties from this one }:)
    Roy Q.T. ~ US/NCU ~ E.E. Technician
    [have tools, will travel]
  19. Guest
    | | ? ? ? writes:
    | ??In alt.engineering.electrical Andrew Gabriel
    | snip<
    | They should've branded & licensed them "Electriv" ?? and sold them
    Could you separate what you are quoting and what you are saying in some way
    so I can tell what is what when I try to read it?
