S
Sam Goldwasser
This one was rather strange, at least to me.
One of two horizontally mounted spiral GE CFLs in a semi-enclosed fixture
simply winked out. It's one I had repaired cracked solder joints on a year
or so ago so I figured time to resolder if the transistors/MOSFETs weren't
toast.
Checked all common suspects for shorts/opens as well as the lamp for
good filaments, no problesm found.
Resoldered some questionable joints - no sign of life.
Then I noticed IT - a dimple near one end of the tube and a resistor
lead could be inserted straight into the inside. A pinpoint on the
inside surface of the glass must have gotten really hot.
How often do you see that?
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
toast.
