fading red eyes
Discussion in 'Electronic Basics' started by [email protected], Aug 25, 2006.
  1. Guest
    Hi all, I'm moderately knowledgable about electronics but have
    forgotten a lot ;)
    I am trying to use the fading red eyes circuit and all I get is the
    LEDs stay on, no fading or anything. I have checked all the connections
    with no result. Hoped someone here might know what could cause this
    Macros
  2. Guest
    If it is simpler, all I really do is for the LEDs to illuminate slowly
    when turned on and fade away slowly when switched off. By putting the
    resiter and LED in series across a 1000 uF cap but I can't get them to
    illuminate slowly,
  3. Eeyore
    Eeyore Guest
    What is this " fading red eyes circuit " ?
    Graham
  4. Greg Neill
    Greg Neill Guest
    You'll need a resistor between the power supply and
    the cap/LED/resistor combo -- there has to be something
    to drop the voltage across while the capacitor charges.
  5. Guest
  6. Guest
    Greg Neill wrote:
    any suggestions for value, I tried that but it just stopped it working
    completely, or perhaps charging toooo slow.
    I'm using a 1000uF cap and a super bright blue 5mm LED with 9v supply.
    Thanks for the help.
    Macros
  7. ehsjr
    ehsjr Guest
    We can't see what you have done. Post a picture
    of what you built. Also, replace the blue LED with
    red leds, at least until you get the thing working
    as per the Bowden design.
    Next: if you followed the schematic, either the transistor
    is always turned on, or is mis-wired, or is shorted. You
    can disconnect the wire from pin 1 of the 1458 to the base
    of the transistor - if the leds still glow, your transistor
    is shorted or wired wrong. Do you have a DMM?
    Ed
  8. Tom Biasi
    Tom Biasi Guest
    How can a "super bright blue 5mm LED " make fading RED eyes?
    What is the forward drop of those LEDs?
    Tom
  9. Guest
    I've gone off the fading red eyes idea as it pulses continuously. All I
    want is for it to come on slowly when I switch it on and fade away when
    I switch it off. It is for a stage prop, goes in the top of an ornate
    staff.
    I think the simple circuit across a cap is what I need, just gotta
    figure out the resistor combinations.
    Not sure what the drop over the LED is and what is a DMM?
    Thanks for the help, will play around with some resistor combos today
    and see how I go.
    I still want the fading red eyes for something else, but best get this
    one done first ;)
    Macros
