Factory menu help-- Panasonic CT-31G30T
Discussion in 'Electronic Repair' started by Suburban, Jul 28, 2004.
  1. Suburban
    Suburban Guest
    Need to get into factory menus to set Vert. Height, and width.
    Ken Marshall
    Suburban Electronics
    614 8767713
  2. Art
    Art Guest
    menu, setup, select cable mode, menu, timer, select 30 min or more, menu,
    exit, select channel 124 all with remote. press volume down button on front
    of tele until you get CHK in upper left of raster. Press power button on
    remote and go from there. 1/4,2/5,3/6 all do different things. Write down
    the parameter location, page, and data value before you change anything.
    Once you find the vert size and lin adjustments write down the preset value
    before changing values. Then adjust to your preferences. Action and power
    buttons on the tele pressed until the set pulses off and back on showing a
    data screen with "OK" marks for the diagnostics. Power it off and back on
    resetting the channels, time, etc. If you suddenly had a change in the
    vertical size and lin service the problem before doing any messing with the
    menu. Improper operations of the circuitry can not be corrected by fubar in
    the service menu. Be advised, if you screw it up, take it to a service shop
    and tell the technician exactly what you did and why.
