Factory Default for Napco 1016e?
Discussion in 'Security Alarms' started by [email protected], Aug 27, 2005.
  1. Guest
    I'm getting ready to replace an older Napco MA1016e with a newer Ademco
    Vista 15P panel. Before I remove the Napco, I'd like to set it back to
    factory defaults. Is there an easy way to do this (I have the
    installer code)? I can remove all of the values using Napco
    Quickloader software, but I'm hoping there is an even easier way to do
    it.
    Lastly, what is the default installer code for these old Napco panels?
    Rob Houston
  2. Jim Rojas
    Jim Rojas Guest
    Nope...the easiest way is to use the software and download a clean file to
    it.
    Jim Rojas
  3. Guest
    Okay, Jim, Thanks! What is the default installer code that I should
    restore for Napco?
    Thanks again,
    Rob
  4. Jim Rojas
    Jim Rojas Guest
    456789
    Jim Rojas
  5. I'm getting ready to replace an older Napco MA1016e with
    Create a new "account" with the software. Don't enter any
    information in it. Download it to the panel.
    It's been a while since I worked on a 1016e but ISTR it's 456789,
    same as several other Napco panels.
    Regards,
    Robert L Bass
    Bass Burglar Alarms
    The Online DIY Store
    http://www.BassBurglarAlarms.com
  6. Guest
    Thanks, Robert. Creating a new "blank" account is an excellent idea!
    Rob
  7. Thanks, Robert. Creating a new "blank" account is an excellent idea!
    No problem. Before you do it, make sure you know what the old
    settings are. It will save you some work reconstructing the
    program later.
    Regards,
    Robert L Bass
    Bass Burglar Alarms
