F2F decoding algorithm-magnetic stripe reader pro.
Discussion in 'Electronic Design' started by solmaz, Jul 22, 2003.
  1. solmaz
    solmaz Guest
    hello
    I need some algorithm that will decode the F2F signal and output
    data+clock signals simultaneously. I will load the program into a
    flash based microcontroller. I already have the circuitry that reads
    the magnetic analog signal from a magnetic card and amplifies and
    converts it to F2F waveform. Remaining part is to decode the F2F
    waveform and get the clock+data output. I somehow figured out how to
    get data output but I still havent found a way to obtain clock output.
    any little suggestion will work.
    regards
    MemeT
  2. : Remaining part is to decode the F2F
    : waveform and get the clock+data output. I somehow figured out how to
    : get data output but I still havent found a way to obtain clock output.
    : any little suggestion will work.
    You can't have data without the clock, so you're mostly there already.
    Use the time between pulses during the leading 0s to establish the bit
    clock period. Thereafter, a pulse around the middle of that time
    period indicates a 1. No pule and it was a 0. A little DPLL could go
    a long way here.
  3. As so often happens, this problem is far more complex than it sounds.
    Card velocity often varies radically throughout the swipe so picking a
    fixed sampling interval is a recipe for failure. Flexing the card while
    swiping introduces various kinds of bias which show up as differences in
    pulse position and amplitude. Head magnetization causes skews in pulse
    size (e.g. wide "highs" and narrow "lows"). All these things need to be
    dealt with in order to get reliable reads under all conditions.
  4. : As so often happens, this problem is far more complex than it sounds.
    : Card velocity often varies radically throughout the swipe so picking a
    : fixed sampling interval is a recipe for failure. Flexing the card while
    : swiping introduces various kinds of bias which show up as differences in
    : pulse position and amplitude. Head magnetization causes skews in pulse
    : size (e.g. wide "highs" and narrow "lows"). All these things need to be
    : dealt with in order to get reliable reads under all conditions.
    Good and valid points. Would you find a DPLL a bad place to start? A
    fuzzy ANN stuffed onto a cheap 87LPC76x?
  5. It falls more into the realm of digital filtering rather than a DPLL.
    I've seen velocity variations as high as 5:1 over a few hundred samples
    so trying to track that with a DPLL would be difficult. Hardware I've
    been previously involved with captured the time intervals between
    transitions and then post-filtered the result to extract the data.
  6. go to Magtek web there are plenty of appnotes
    Best regards
    Tsvetan
  7. : thought that it might be easier to do the reading and encoding job
    : with a PIC microcontroller(16f628, 16f84 etc.) rather than PLL because
    : of the flexibility of the software routines.
    DPLLs are easy to implement in software. Realizing a robust decoder
    with one is another kettle of fish. How much clock/speed variation
    is expected within a swipe?
  8. The greater than 5:1 variations I mentioned in a previous post is what I
    have seen within one swipe. The way many people use a reader is they
    position the card in the slot near the read head and then accelerate the
    card throughout the swipe. "Dunk" readers are even worse as the card is
    already in contact with the head and accelerates from a standstill as
    the card is removed.
